It is currently Mon May 20, 2013 2:06 pm
 Post subject: N00b Question About Phenom x4 9850 TDP @ 3.1ghz...
PostPosted: Sun Dec 05, 2010 11:43 pm
Million Club
Million Club
So here it is:
How many watts will an AMD Phenom x4 9850 2.5ghz (The 125-watt version)
draw when overclocked to 3.1ghz (It's maximum stable speed), and at full-bore
usage (Say, Prime95 or F@H)??
 Post subject: Re: N00b Question About Phenom x4 9850 TDP @ 3.1ghz...
PostPosted: Mon Dec 06, 2010 8:13 am
Million Club [PC]
Million Club [PC]
It depends on the voltage you pumped into it mostly. At an average voltage for that kind of overclock, power consumption might be as high as 200W or so.
PostPosted: Mon Dec 06, 2010 12:18 pm
If you just use the cpu overclock function here you should be able to get an idea. As Spartacus said it really depends on your vcore. I threw in 1.4v instead of 1.2 just to see with your oc (again I dont know what v you actually use) and get a wattage of 211.
PostPosted: Mon Dec 06, 2010 6:01 pm
Million Club
Million Club
OK, configured to my system's specs, it says that using a 1.3v overvolt (1.25 stock), with a 600mhz overclock, I should see 184 watts.
Now the questions is, will my Foxconn Destroyer handle that?
It supports a 125~140 watt CPU, but will it handle the full force of running the processor at full bore, overclocked to 3.1ghz, without burning up the v-regs?
hmmmm..
PostPosted: Mon Dec 06, 2010 9:18 pm
Million Club [PC]
Million Club [PC]
Yeah it ought to be fine.
PostPosted: Tue Dec 07, 2010 7:05 pm
Million Club
Million Club
Thanks for both of your help, guys. The board should be here this week - ordered just before the rush and paid extra for shipping. All set and ready to replace my almost-burnt-out Asus; it was not in good shape when I got it, but I have had the Phenom running at 2.0ghz on it to reduce it's impact on the board, which did not support the 125 watt CPU, but only 65~95 watt CPU's. The underclocked proc, even under full load with no voltage change, will only burn 100 watts. So while I should be fine for now, I wanted the 3.0ghz clock so that I can feel somewhat justified running the SMP client on it and it still pay off. I could run it now, but a sngle WU would take 3-6 days depending on size, compared to the 1.5-2 days it takes at 3.1ghz.
Thanks again!
:mrgreen:
