It is currently Fri Mar 27, 2015 8:21 am
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
 Post subject: Re: (Discussion) Pathfinding
PostPosted: Tue Nov 16, 2010 5:11 am
Bitchin' Fast 3D Z8000*
Dwood15 wrote:
Perl could handle that server idea quite easily, and implement a HiRes timer pretty well.
Personally, I think that tracking the number of client/server queries would be more relevant concerning algorithm performance which is mostly going to tell us who has the best internet connection and/or lives near you.
The other issue with using a network client/server system is that it creates quite a bit of extra work for the client developers (not too mention the server code). How many people here have network programming experience?
PostPosted: Tue Nov 16, 2010 11:46 pm
Oh sorry I forgot all the other languages you peeps use can't just place the output in the form of a webpage and send it back a easily as perl can yas? :P
PostPosted: Wed Nov 17, 2010 5:25 am
I have done a very tiny bit of network stuff... in Java... and most of that was copy and paste to get a stupid app working that was really unrelated to the actual network stuff.
C# handles web just fine Mr Wood! So stuff it. :)
PostPosted: Wed Nov 17, 2010 10:05 am
Is that a challenge? :lol:
PostPosted: Wed Nov 17, 2010 12:14 pm
Truth be told, I don't have time to... :(
I really need something "fun" to work on.Things have been busy at work and definitely not fun lol.
PostPosted: Wed Nov 17, 2010 3:13 pm
Perl can automatically create html output? Interesting...
Perl "just places the output" as an html page? That's pretty cool, but how does it know that I want the output to a matrix placed in a table w/ or w/o borders? That negative values should be colored red? Truth be told, many languages have various degrees of network support built-in... Java, Clojure (by extension... or any language running on the JVM for that matter), C#, Obj-C, Python, Common Lisp and quite a few others to boot. Ansi-C is the only other industry standard language that I can think of offhand where I'm certain there isn't network support built-in (other, less certain, languages would include C++ and Scheme... I'm 50/50 on Smalltalk and Ada).
However, there is another, more important, difference... no other language is nearly as FUGLY as PERL!!! =)
PostPosted: Wed Nov 17, 2010 3:27 pm
Dwood - If you create the server code, I'll go ahead and write some code to make random mazes of various sizes.*
* Since Perl doesn't seem to have an auto-feature for mazes. ;P
PostPosted: Wed Nov 17, 2010 4:28 pm
if ($number < 0) {
print "<b> $number </b>";
else { print "$number"; }
I find perl a beautiful language, after having learned the basics but i'm going to need to look up its web items before I jump in to this head first.
As it stands the script would be (imo) incredibly simple. Design the output of the matrices so I know how to work with them, I can design the matrix navigation in less than an hour... I've always been iffy with file input though. ;)
I'll see if I find the time to do it by friday or so.
PostPosted: Tue Nov 23, 2010 10:50 am
I wrote some code that generates mazes in the small to medium size range. In the process, I came up with a different approach for generating large mazes that I may or may not implement depending on how many people get involved with this path-finding project.
I think the symbol encoding that I've used is fairly natural for programming and visual inspection:
S = start location
G = goal location
X = wall location
. = path location
;;maze1
;;S......XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
;;XX.XXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
;;XX.XXX.XXXXXXXXX.......X........XXXXXXXXXXXXXXXXXXXXXXXXXXXX
;;XX.XXX.XXXXXXXX..X..X....XXXXXX.XXXXXX......XXXXXXXXXXXXXXXX
;;XXXXXX.....XXX..XX.......XXXXXX........XXXX.......XXX......G
;;XXXXXXXXXX..XX.X.X...X..XXXXXXXXXXXXXXXXXXXXXXXXX.....XX....
;;XXXXXXXXXX.XXX.X.XX.......XXXXX...XXXXXXXXXXXXXXXXXXXXXX.XXX
;;XX................X....X.XXXXXX.........XXXXXXXXXXXXXXXX...G
;;XX.XXXX.XXXX...X...X..X..........XXXXXXXXXXXXXXXXXXXXXXXXXXX
;;XX......XXX....X.XX...X..XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
;;maze3
;;S.XX..X..X......X.........XXXXXXXXXXXXXX.XX.X.X..................X..X.X........G
;;.X.X.....XX...X.X.X..X..X.XXXXXXXXXXXXX...X.X.XX...X.....X.X.....XX...XX........
;;...X.X.X......X.XXXX...X..XXXXXX..XXXXX...X...X..X...X......X......X.....X......
;;....XXX......XX..XX.......XXXXX.X..X.X......X..XX.X....X......X....X...X.X.XX.XG
;;.X..X.........X..X..X...XXXXXX....X..X.....XX........X.....XX..X.X.X............
;;...XX......XX.......X...X.XXX..X......X............X.X.X....XX....X....XXX.XX..G
;;......XX..X...X.X...X......X..XXXXX..X.....X.XX.X.X..X..X...X..X.XXXX..XXX....X.
;;XXXX.....X...X.X..XX.X......X.X........XX..X......X....XXXX.X....X...X.......X..
;;.X.....XX.........XX...XX.XXX.X...XX....XXX..........X..XX....X....X..X....X...G
;;....XXXXX......X.X.....XX...........X...XX....X...X.....XXX....X.X..XX.XX..X...X
;;.XX....X......X.XX.XX.X.....XX......X..XX....XX.X......X.....XXXXXX.....X.......
;;..X.....X..X.....X.XX.X......X...X....X...XX.XX.X...X.XX.XX......X...XX..XX.X..G
;;....X..X.X.X..X..X......X.....X.....XXX......X................XX...X..XX.X..X...
;;XXX..........XXX....X...XX.......X.XXXXXX..X..XX....X..X.XX...XX.X....X..X..X..X
;;XX......X.X.....XX..X..X...X.....X..XXXX...X..X.....X....XXX.X....XXX...X.......
;;.X.X.XXX............XX......X...X.XXXXX.X....X......XXX.X.XXXX....XXXX....X....X
;;.X..X.........X.....X..X...X.XX.X..XXX..X.....X....XXXX.....X.X.X....X......X...
;;.X.X....X..XX..X......X..X.X.X...X...XX..XX....X.XXXXXX.....X....XX.X........XX.
;;...XX..X....X.......X.X..X.X.......XX.X..X........X.XX...X.XXX.X...XX........X..
;;..X....XX..XXX.X...........X....X...X........X.X.........X.....X...XXX......XX..
;;maze4
;;S.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX..XXXXXXXXXXXX.......XXXXXX....XXXX
;;.XXXXXXXXXXXXXXXXXXXXX......XXXXXXXX..........XXXXXXXXXXXX..XXXXX..XXX...X.XXXXX
;;...XXXXXXXXXXXXXXXXXXXX..X........X..XXXXXXXXXXXXXXXXXXXX..XXXXXX.X...XXXX..XXXX
;;XX..XXXXXXXXXXXXXXX......XXXXXXX.....XXXXXXXXXXXXXX...X....XXXXXXXXXXX.XXX..XXXX
;;XX..XXXXXX....XXXX..XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX......XXXXXXXXXXXXXXXXX..XXXXX
;;XX.XXXXXX..XX.......XXXXXXXXXXXXXXXXXXXXXX.........X.XXXXXXXXXXXXXXXXXXXX..X.XXX
;;XX....XX..XXXXXXX...XXXXXXXXXXXXXXXXXX.....XXXXXXXXX.XXXXXXXXXXXXXXXXXXXXX...XXX
;;XXXXX....XXXXXXX..XXXXXXXXXXXXXXXXXXXX.XX..XXXXXXXXX...XXXXXXXXXXXXXXX..XX.....X
;;XXXXXXXXXXXXXX....XXXXXXXXXXXXXXXXXXXX..XXXXXXXXXXXXXX..XXXXXXXXXXX............G
;;XXXXXXXXXXXXX..X.XXXXXXXXXXXXXXXXXXXXX..XXXXXXXXXXXXXX..XXXXXXXXXXXXXXXXXXXXXXXX
;;XXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXX..XXXXXXXXXXXXXX..XXXXXXXXXXXXXXXXXXXXXXXXX
;;XXXXXXXXXXXXX....XXXXXXXXXXXXXXXXXX...XXXXXXXXXXXXXXX.XXXXXXX....XXXXXXXXXXXXXXG
;;XXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXX....XXXXXXXXXXXXXXXXX.........XX...XXXXXXXXXXX..
;;XXXXXXXXXXXXXXXX....XXXXXX.......XXXXXXXXXXXXXXXXXXXXXXXXXX...XXXX....XXXXXXXX.X
;;XXXXXXXXXXXXXXXXXXX.XXXXXX.X.....XXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXX...XXXXXX..
;;XXXXXXXXXXXXXXXXXXX.XXXXXX..X...X.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX....X....X
;;XXXXXXXXXXXXXXXXXXX.XXXXXX.X.XX.X..XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX......X...
;;XXXXXXXXXXXXXXXXXXX...XXXX.X.X...X...XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX........XX.
;;XXXXXXXXXXXXXXXXXXXXX.XXXX.X.......XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX........X..
;;XXXXXXXXXXXXXXXXXXXXX......X....X...XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX......XX..
;;maze5 -- Not generated, just an example of why I think A* is going to have problems w/a maze
;;S............X.XX.XX.X.X.X.X...XXXXXXXXXXXXXXXXXXXXXXXXXXXXG
;;.XXXXXXXXXXX.X.XX.XX.X.X.X.X.X.X...X...X...X...X...XXXXXXXX.
;;.XX..........X.XX.XX.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.....XX.
;;.XX.XXXXXXXXXX.XX.XX.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.XXX.XX.
;;.XX............XX.XX.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.XXX.XX.
;;.XXXXXXXXXXXXXXXX.XX.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.......XX.
;;.X................XX.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.XXXXX.XX.
;;.X.XXXXXXXXXXXXXXXXX.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.XXXXX.XX.
;;.X...................X.X.X.X.X.X.X...X...X...X...X.......XX.
;;.XXXXXXXXXXXXXXXXXXXXX.X.X.X.X...XXXXXXXXXXXXXXXXXXXXXXXXXX.
;;.X..................XX.X.X.X.XXXXXX......................XX.
;;.X.X.XXXXXXXXXXXXXX.XX.X.X...XXXXXX.XXXXXXXXXXXXXXXXXXXXXXX.
;;.X.X.X...XXXXXXXXXX.XX.X.XXXXXXXXXX......................XX.
;;.X.X.X.X.X...XXXXXX.XXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXX.
;;.X.X.X.X.X.X.XXXXXX......................................XX.
;;.X.X.X.X.X.X.X...XXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXX.
;;.X.X.X.X.X.X.X.X.X...X...X...X...XX......................XX.
;;.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X.X..X.XXXXXXXXXXXXXXXXXXXXXXX.
;;.X.X..XX...X...X...X...X...X...XXXX......................XX.
;;.X.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.
;;...X...X.................................................XX.
;;.X.X.X.X.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XX.
;;.X.X.X.X...........................XXX...................XX.
;;.X.X.X.X.XXXXXXXXXXXXXXXXXXXXXXXXXXXX..XXXXXXXXXXXXXXXXXXXX.
;;.X.X.X.X.........................XXX..X....XX.X.X.X.X.X.XXX.
;;.X.X.X.X.XXXXXXXXXXXXXXXXXXXXXXXXXX..X..XX.XX............XX.
;;.X.X.X.X.......................XXX..X..XX..XXXXXXXXXXXXX.XX.
;;.X...X...XXXXXXXXXXXXXXXXXXXXXXXX.....XX.................XX.
;;.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.
PostPosted: Tue Nov 23, 2010 10:55 am
The forums create a catch-22 with larger mazes. I don't really feel like setting up a gmail account in order to 'share' a few KB of data, but I also don't want to 'break' the pages with larger mazes either. Instead of using the expanded format above, I'll post larger mazes in a run-length encoded (RLE) compressed format. RLE compression should work fairly well for this type of data and is a cinch to code up.
;;maze 1 example...
(setf m1-enc "1S6.55X1.3X1.55X1.3X1.9X7.1X8.30X1.3X1.8X2.1X2.1X4.6X1.6X6.22X
5.3X2.2X7.6X8.4X7.3X6.1G10X2.2X1.1X1.1X3.1X2.25X5.2X4.10X1.3X1.1X1.2X7.5X3.22
X1.5X16.1X4.1X1.6X9.16X3.1G2X1.4X1.4X3.1X3.1X2.1X10.29X6.3X4.1X1.2X3.1X2.35X")
(setf m1-rows 10)
(setf m1-cols 60)
(defun print-encoded-maze (maze-enc num-rows num-cols)
  "Utility function for printing an RLE maze."
  (let ((maze-dec (rle-dec maze-enc)))
    (loop for i from 1 to num-rows
     for start = 0 then end
     for end = num-cols then (+ end num-cols)
     do (format t "~a~%" (subseq maze-dec start end)))))
(print-encoded-maze m1-enc m1-rows m1-cols)
PostPosted: Thu Dec 02, 2010 1:41 pm
Sorry gadget, It's going to take me a little longer to do anything I want to do- my classes just started picking up, entering into crunch time right now so any free time I have I won't want to be on the computer haha, but I'll take a peek at it -eventually- lol.
PostPosted: Tue Dec 14, 2010 6:25 pm
Huh, what... I thought Perl did all of the work for you?! =)
Good luck on your finals.
PostPosted: Thu Dec 16, 2010 11:57 am
I needed to have system access to do Homework::Study::FinalsForMe;
But the server I'm on which would run it, I don't have access to install the module. (code made for running only in cgi's pffft)
