It is currently Thu Jan 29, 2015 5:38 am
 Post subject: The Countdown Problemie
PostPosted: Mon Oct 04, 2010 6:33 pm
Bitchin' Fast 3D Z8000*
I came across this problem watching a MSFT video. Personally, I think that it looks pretty interesting...
Problem: You are given six positive "source" numbers and a final answer. All of these will be natural numbers. Using the standard arithmetic operators (ie + - * /), construct an arithmetic statement using the source integers that is equal to the answer.
Constraint 1: All intermediate calculations must result in positive natural numbers.
Constraint 2: You may only use a source number one time; However, you're not required to use all of the source numbers.
Example: Given source = {2 5 9 12 18 40} and answer = 50. One possible answer is 5 * 18 - 40.
Any takers? =)
 Post subject: Re: The Countdown Problemie
PostPosted: Tue Oct 05, 2010 6:27 am
Fun! I'll think about this today at work and see if I can drum something up.
Since you don't have to use all of the source numbers, my first pass would be to find the factors of the answer and play with those.
PostPosted: Wed Oct 06, 2010 4:01 am
As usual, the brute-force solution is pretty obvious, but I'd really like to come up with a method for finding a minimal length solution quickly (other than using BFS). I keep thinking that a best first search might be pretty good -- not sure though.
I went ahead and watched the rest of the Channel 9 video, which kind of took a turn for the worse. The problem went from finding a single solution to counting all solutions. Fine. Of course, the initial program wasn't fast enough otherwise there wouldn't have been much point in posting the video. Of course, this was exaggerated because the author was trying all permutations of length 6, so he suggested chopping down the search space by not computing the invalid expressions. A pretty obvious todo when using search except he didn't search and called it "program fusion".
He further sped up the program by eliminating equivalent expressions (ie 1*2*3 = 1*3*2 = 2*1*3 = 2*3*1 = 3*1*2 = 3*2*1) , but conveniently neglected to keep the same counting method (ie returning 1 now instead of 6 as before).
Also, I believe his program would have returned 1*2*3 instead of 2*3. Oh well. The problem is still pretty interesting. =)
PostPosted: Thu Oct 14, 2010 5:40 pm
Have you thought about it anymore? Just curious, how big of a boat would I need to travel the oceans of this world safely?
PostPosted: Thu Oct 14, 2010 8:16 pm
40'+ monohull, 35'+ cat .. assuming you're taking the safest passages across bluewater
PostPosted: Sat Oct 16, 2010 11:51 am
If I move back to LA, I'm considering buying a boat and just living in the marina (Marina Del Rey). 40' is a big boat... I'm not sure if I want to Google the slip fee.
PostPosted: Sat Oct 16, 2010 5:42 pm
40' is also quite large for someone to single-hand ... if you have a partner, you'll be ok but alone that is a LOT of boat to handle.
Of course, you'd never make a bluewater passage alone .. right? ;)
A liveaboard is a great idea .. I'd look into a cat in that case, though. More than twice the available space for the same beam.
PostPosted: Sat Oct 16, 2010 11:14 pm
What's this?! I thought you were looking forward to ski season!
I didn't know that... good to know!
PostPosted: Mon Oct 18, 2010 9:04 am
:lol:
I wasn't actually offering to come with (though .. woo!) .. just pointing out that any time you leave shore, you have to have someone on watch at all times. The passage from LA to Hawaii, for instance, is over 2000 knots .. given an average speed of 6 knots / hour for a monohull in bluewater (12 for a cat), you're looking at 2 week passage in bluewater. Unless you can stay awake for 2 weeks ... you really need a second hand on board.
Cats are fantastic. Faster, more stable, easier to sail and far more space. Also far more expensive. ;)
