It is currently Tue May 21, 2013 1:14 pm
 Post subject: sli
PostPosted: Sat Oct 09, 2010 9:37 pm
I know I probably sound like and idiot but, if I bought two different cards that boat support sli/crossfire will they run together?
 Post subject: Re: sli
PostPosted: Sun Oct 10, 2010 12:22 am
Million Club [PC]
Million Club [PC]
How do you mean different? As in different models from Nvidia (eg. 7600 vs. 8800) or same model from a different board manufacturer (e.g. BFG 9800GT and EVGA 9800GT)? If its completely different card models, no. If its the same card from different board partners, it'll work.
PostPosted: Mon Oct 11, 2010 1:39 pm
so basically if has the same chipset it will work. Ok I get it! :idea:
Thanks!
PostPosted: Wed Oct 13, 2010 1:58 pm
ok, so will these two cards work together?
Galaxy 96GFF6HUUEXV GeForce 9600 GT OC 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
EVGA 512-P3-N865-AR GeForce 9600GT KO 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
PostPosted: Wed Oct 13, 2010 2:11 pm
Million Club - 20 Plus
Are you going to buy them?
Ted
PostPosted: Wed Oct 13, 2010 3:20 pm
Million Club [PC]
Million Club [PC]
If you already have them, yeah, but don't buy them unless you're getting each for under $50.
PostPosted: Thu Oct 14, 2010 2:34 pm
ya I was actually buying them for $35 each so I thought it was a pretty good deal. thanks!
PostPosted: Thu Oct 14, 2010 4:41 pm
I still wouldn't buy them. Would a GT 430 outperform them for only $10 more?
Ted
PostPosted: Thu Oct 14, 2010 10:35 pm
Million Club [PC]
Million Club [PC]
Heck no. A GT 430 hardly beats one 9600GT. For $35 each, that's not bad at all if your motherboard supports SLi and your PSU can handle them.
