It is currently Thu Mar 05, 2015 3:11 am
 Post subject: Portable PowerPoint 2010 Viewer
PostPosted: Sat Oct 02, 2010 6:55 am
I have office 2010, but the school I go to only has 2000 and the affects that I have wont work. Is there any portable powerpoint viewer that I could run from my flash drive to show my power point with all the right colors and affects?
Thanks!
 Post subject: Re: Portable PowerPoint 2010 Viewer
PostPosted: Sat Oct 02, 2010 7:48 am
Google is your friend, try using it.
PostPosted: Sat Oct 02, 2010 7:50 am
I have used Google. Plus the link that you posted requires that I install it to the computer. I have already attempted to make it portable.
PostPosted: Sat Oct 02, 2010 8:03 am
Sounds like you're looking for this...
http://www.microsoft.com/downloads/en/d ... 4eeb832823
IIRC, having a portable viewer (or even converting to a stand-alone exe) isn't going to solve this and the subject computers still need the Microsoft Office Compatibility Pack (or Powerpoint 2007) still installed.....and even then, I'm not certain if the effects you're talking about will show up.
PostPosted: Sun Oct 03, 2010 9:50 am
Malware specialist
Malware specialist
I would say your best bet would be to save the file in the 97-2003 version. The program will alert you when saving if you chose something that won't work.
PostPosted: Sun Oct 03, 2010 10:26 pm
Try Open Office portable. It will work on some PPT files but it is a bit of a crap shoot.
PostPosted: Mon Oct 04, 2010 5:54 am
Thanks!
Wait, you can't publish a PowerPoint anymore? :shock: Ever since using I've been using PowerPoint, there was always been an option to publish it to a CD/DVD. Hell, I just publish it to a folder then move it to a flash drive. Done and done.
PostPosted: Tue Oct 05, 2010 4:40 am
Alternately you could talk to the professor about getting the M$ viewer installed on the computers in the classroom. It's a freebie so there would be no cost other than the time to download and install it.
PostPosted: Sun Jan 19, 2014 6:21 pm
hI THERE
That exactly what i want to get.I am looking for a
Powerpoint viewer which supports to run from my flash drive to show my power point.
I have installed another Powerpoint tool before.But it can not work with flash drive effectively.
I want to get a free trial before i decided to purchase it.Thanks for any suggestions.
