It is currently Tue Jun 18, 2013 10:58 pm
 Post subject: This stupid computer won't obey my commands
PostPosted: Mon Sep 27, 2010 6:56 pm
Professional Dork
Professional Dork
Alright then. I had a Windows Server, um, server, that died and ate my data. Now I've rebuilt it and loaded a backup, but I can't get the fucker to share files.
Running Ubuntu Server 10.4 with GNOME loaded because I'm fucking useless without a goddamn GUI.
I installed Samba and I can share a folder that is on the root drive. For example, if I share /testfolder via samba, it shows up on my wife's Windows laptop, and I can open and browse the folder. Same thing on my Ubuntu desktop.
Now, the drive that I'm trying to share is a RAID device (mirrored disks). I've managed to make this bastard understand to start the fucking RAID device on startup, and even made it mount the drive in /data.
Yet it still looks at me like I just fucked its sister when I try to open and browse a share on the RAID device, at least from the Ubuntu side. From Windows, it tells me that Windows can't access it and to check the name. I mean, I'm quite certain of the name since it appears as an available share on the server, which does show up in Network Neighborhood.
There has got to be a solution to this, and given the amount of work I've put into getting the fucker to work, I am quite certain that I'm going to feel like a goddamn idiot when someone tells me what it is (this, of course, is known as the "the harder you try, the easier the solution" method of problem solving).
 Post subject: Re: This stupid computer won't obey my commands
PostPosted: Mon Sep 27, 2010 7:30 pm
My first thought is are you allowing guest access...basically guest ok =yes in your smb.conf.
Perhaps changing the owner or your mount point to nobody may give you some love.
PostPosted: Mon Sep 27, 2010 7:49 pm
Professional Dork
Professional Dork
guest ok = yes is set
I chown'd the /data folder to nobody, and I got the same thing.
PostPosted: Mon Sep 27, 2010 8:05 pm
I assume you restarted samba after doing that?
I dunno...what's your conf look like?
PostPosted: Tue Sep 28, 2010 3:05 am
Professional Dork
Professional Dork
Stripped out the comments
[global]
   workgroup = WORKGROUP
   server string = %h server (Samba, Ubuntu)
   dns proxy = no
   log file = /var/log/samba/log.%m
   max log size = 1000
   syslog = 0
   encrypt passwords = true
   obey pam restrictions = yes
   unix password sync = yes
   passwd program = /usr/bin/passwd %u
   passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
   pam password change = yes
   map to guest = bad user
#======================= Share Definitions =======================
wins support = no
[printers]
   comment = All Printers
   browseable = no
   path = /var/spool/samba
   printable = yes
   guest ok = no
   read only = yes
   create mask = 0700
[print$]
   comment = Printer Drivers
   path = /var/lib/samba/printers
   browseable = yes
   read only = yes
   guest ok = no
# THIS ONE DOESN'T WORK
[admin]
   path = /data/admin
   comment = admin data
   read only = no
   writable = yes
   guest ok = yes
   browseable = yes
# THIS ONE DOES
[testshare]
   path = /testshare
   comment = test
   read only = no
   writable = yes
   guest ok = yes
   browseable = yes
PostPosted: Tue Sep 28, 2010 6:29 pm
Professional Dork
Professional Dork
I'm 99% convinced that my problem is related to the RAID drive.
PostPosted: Tue Sep 28, 2010 8:12 pm
I would agree, but I think it just boils down to a permission or a UUID that's gone awry...
For some reason I want to think that I thought you needed /dev/md0 (or whatever your raid is) in the path, but I could be wrong there.
What's your mdadm.conf look like?
PostPosted: Wed Sep 29, 2010 4:02 pm
Professional Dork
Professional Dork
# mdadm.conf
# Please refer to mdadm.conf(5) for information about this file.
# by default, scan all partitions (/proc/partitions) for MD superblocks.
# alternatively, specify devices to scan, using wildcards if desired.
DEVICE partitions
# auto-create devices with Debian standard permissions
CREATE owner=root group=disk mode=0660 auto=yes
# automatically tag new arrays as belonging to the local system
HOMEHOST <system>
# instruct the monitoring daemon where to send mail alerts
MAILADDR root
# definitions of existing MD arrays
# This file was auto-generated on Sat, 25 Sep 2010 14:21:45 -0500
# by mkconf $Id$
ARRAY /dev/md0 devices=/dev/sdb1,/dev/sdc1
PostPosted: Thu Sep 30, 2010 4:40 am
Professional Dork
Professional Dork
Now I'm thinking that I'm just going to use my primary drive to store data and use the 500's to back up to.
Googling, I found a few things, including chmod and chown commands, but none of that helped.
PostPosted: Thu Sep 30, 2010 7:25 pm
Professional Dork
Professional Dork
All right. This is just F'n weird.
If I share /data, it works.
If I share /data/admin, it doesn't work.
It doesn't seem to matter what directory I'm trying to share. So if it's on the primary drive or on a RAID device or what.
For some reason, it just hates me trying to share anything not on the root of the drive.
What the hell
PostPosted: Thu Sep 30, 2010 7:31 pm
Try changing
CREATE owner=user (you) group=users mode=0666 auto=yes
erk...just saw your last post....by chance are you using the -R flag when setting your permissions?
PostPosted: Thu Sep 30, 2010 7:55 pm
Professional Dork
Professional Dork
furball146 wrote:
Try changing
Yes.
