It is currently Wed Jun 19, 2013 7:54 pm
 Post subject: router orientation
PostPosted: Mon Aug 16, 2010 2:10 pm
I was looking through the instructions for my DLink DIR-655 Wireless N router, and it says that the "preferred" orientation of the router is to sit horizontally. But it comes with a vertical stand. Could the orientation of the router (horizontal or vertical) affect its performance or usable life?
I could see that certain things might possibly overheat over time if it was vertical as opposed to horizontal, but is there any real problem with one over the other?? Do you get better performance/speed/range by having it horizontal?
 Post subject: Re: router orientation
PostPosted: Mon Aug 16, 2010 2:19 pm
Do you, for half a second, think this is a networking problem that you need educated upon?
Grrrraaaaghhh! Stickies...read 'em. This is the emergency room dude. Read the titles and you go where you think it fits. If you think this is the education area, then we have a long life together. (I'd usually just move it, but that's gone).
Networking nook sound good?
PostPosted: Mon Aug 16, 2010 2:27 pm
oops my fault. I've been up for about 24+ hours so far, and had a little lapse in memory apparently.. I looked up and down the list a few times and finally said aw heck. forgot about Network Nook. Can you remove this post so I can repost it there without the consequences of double-posting -- since I can't now that there are replies??
PostPosted: Mon Aug 16, 2010 3:49 pm
Team Member [Top 500]*
It will be happier here in the Network Nook. :)
Ron
PostPosted: Thu Aug 19, 2010 9:29 pm
Hired Gun
Hired Gun
Ron
Agreed, it's a Network related question, even if it isn't an "Emergency". We take routine questions as well.
PostPosted: Mon Aug 30, 2010 4:28 am
I have a Netgear wndr3700. When I first set it up I had it oriented horizontally in our upstairs office (seemed more stable (not able to knock over)). But, I was having reception problems on the 1st floor of my house.
I changed the orientation to the vertical position and got much better distance performance over the entire house (strong signal strength at the opposite corner of the house and downstairs).
