It is currently Sat Jan 31, 2015 5:59 am
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed Aug 04, 2010 10:38 am
I just wrote a C# two-line program that solves this:
var Say = (string s) => {Console.WriteLine(s);return true;};
for(int i = 1; i <= 100; i++) if(!(i % 3 == 0 && Say("Fizz") && i % 5 == 0 && Say("Buzz"))) Console.WriteLine(i.ToString());
Beat that :)
PostPosted: Wed Aug 04, 2010 1:19 pm
All of the above solutions beat that.
What value do the Say("xxx") methods return? Do they are return a value? Is it Boolean?
Gadget's solution is O(1). Yours is O(n). You aren't playing in the same ballpark.
PostPosted: Wed Aug 04, 2010 1:52 pm
I meant for line count, not efficiency... and it's pretty obvious what the Say("xxx") methods return, seeing as its definition is on line 1...
PostPosted: Wed Aug 04, 2010 2:01 pm
I admit, I missed that you'd defined it on the first line.
I was too busy laughing at the thought that line count is important.
Did you miss the discussion regarding line count earlier in the thread?
PostPosted: Wed Aug 04, 2010 2:06 pm
There was no discussion, there were two posts. And this is just the optimal line count one. Why do you care so much?
PostPosted: Wed Aug 04, 2010 2:24 pm
I care because you're perpetuating the completely false myth that line count matters. It is annoying.
PostPosted: Wed Aug 04, 2010 2:40 pm
I never said it matters. It doesn't. It's just interesting to find out how short you can make a bit of code. In terms of efficiency, it's usually horrible (though the short-circuiting there is nice).
PostPosted: Thu Aug 05, 2010 3:49 am
They also solved different problems.
PostPosted: Sat Aug 07, 2010 12:09 am
Bitchin' Fast 3D Z8000*
Before getting into your solution, I'm Gadget -- nice to meet you!
Alright, I see a few problems with your solution...
1) In order for you to print a numeral, the entire conditional must be true which only occurs when a number is both a multiple of 3 and 5 (ie a multiple of 15). If the current number is a multiple of 5, but not 3, you won't ever print "Buzz" due to short-circuiting of the and statement (note: I believe that C# does short-circuiting... I could be wrong).
2) If a number is a multiple of 3, you will print "Fizz", but you will follow it with a 3 or 6 or ...
3) You're going to have newline errors. For example, you can either print a newline after "fizz" which works for multiples of 3 (minus issue #1 above), but it will print "fizz\nbuzz\n" for a multiple of 15. Some languages will allow you to use a conditional inside of a print statement, but I doubt that C# supports this functional style of programming (see example below).
Just some thoughts...
(loop for i from 1 to 20 do
          (format t "~a~%"
             (cond ((and (= (mod i 3) 0) (= (mod i 5) 0)) "FizzBuzz")
                   ((= (mod i 3) 0) "Fizz")
                   ((= (mod i 5) 0) "Buzz")
                   (t i))))
1
2
Fizz
4
Buzz
Fizz
7
8
Fizz
Buzz
11
Fizz
13
14
FizzBuzz
16
17
Fizz
19
Buzz
PostPosted: Sat Aug 07, 2010 12:26 am
I just hope that you know if you do this in real-life that someone is probably going to throw a reference book at your head!
Hey guys -- I just noticed an interesting property of multiples of 15. I'm going to start a new FizzBuzz thread to discuss it. Check it out!
PostPosted: Sat Aug 07, 2010 11:26 am
I'd never do it in real life, so I guess there's little chance of anyone doing that :).
You're right - I put an && where I should have changed a bit of logic and put a ||. Here's the new one:
var Say = (string s) => {Console.WriteLine(s);return false;};
for(int i = 1; i <= 100; i++) if(((i % 3 == 0 && Say("Fizz")) || (i % 5 == 0 && Say("Buzz"))) || (i % 3 == 0 && i % 5 == 0)) Console.WriteLine(i.ToString());
PostPosted: Sat Aug 07, 2010 11:38 am
minitech wrote:
Here's the new one:
Around number 15, you'll print...
14
Fizz
Buzz
16
Instead of...
14
FizzBuzz
15
Just curious, what is this line of code doing? Is this some kind of macro system in C#?
It looks like you're creating a macro named Say, that accepts an input string s, which is then expanded into the console writeline call... is that about right?
PostPosted: Sat Aug 07, 2010 11:57 am
Yup, lambdas are new to C# and they're really useful. You're right, I should change it to .Write() instead of .WriteLine()... and that makes the logic easier, too :) Here's a new one:
Func<string, bool> Say = (string s) => {Console.Write(s);return true;};
for(int i = 1; i <= 100; i++) if(!((i % 3 == 0 && Say("Fizz")) | (i % 5 == 0 && Say("Buzz"))) || Say(i.ToString())) Console.WriteLine();
PostPosted: Sat Aug 07, 2010 12:21 pm
That's a lambda function? This seems a bit strange because in most languages a lambda function is a "nameless functions", but here, you've clearly given it the name Say().
Can you do something like the code below (ie write the lambda function at any place that will accept a function)?
CL-USER> (setf foo '(1 2 3 4 5 6))
(1 2 3 4 5 6)
CL-USER> (sort foo #'<)
(1 2 3 4 5 6)
CL-USER> (sort foo #'>)
(6 5 4 3 2 1)
CL-USER> (sort foo (lambda (x y)
           (cond ((and (= (mod x 2) 0)
             (= (mod y 2) 0))
             (< x y))
            ((= (mod x 2) 0) t)
            ((= (mod y 2) 0) nil)
            (t (< x y)))))
(2 4 6 1 3 5)
CL-USER>
PostPosted: Sat Aug 07, 2010 12:47 pm
No, you have to assign them to something unless they're being used in an expression. So this:
myList.Where((x) => x == 4);
is valid, but:
((x) => { return x == 4; })(myValue);
is not.
PostPosted: Mon Aug 09, 2010 4:52 am
is valid, but:
is not.
Gadget's correct, lambda's are nameless functions. Hence the code:
Func<string, bool> Say = ...;
Is not a lambda in true form. Func<TResult> functions more as a delegate (IIRC), so this looks more like an anonymous function call, similar to .NET 2.0.
PostPosted: Mon Aug 09, 2010 9:06 am
It is a lambda, it's just assigned to a variable in that case. I could do this:
myFunction((arguments) => { code });
But having this:
((arguments) => { code })(variable);
doesn't work because a constructor is being called in the background, and C# doesn't allow that:
(new Form()).Show() // Doesn't work
EDIT:
Actually, I guess it works now! :o
PostPosted: Mon Aug 09, 2010 3:50 pm
On the topic of the article I would agree.
Im a double major Computer/Electrical Engineering and Computer Science
and we sit in class and learn that material and then are left to our own devices for programming projects.
In ECE they actually have discussed optimization but thats low level(MIPS,SPARC,IA32,BASIC), and programming projects for some of those classes stipulate solving a problem in a certain number of instructions, which does directly correlate with efficiency most of the time.
CSC courses you only get direct assistance with code if you cant get it working, no regards to optimizing.
If thats the state of the industry i feel a good deal better although real optimization in anything high level is on the list of things i wish i knew.
PostPosted: Tue Aug 10, 2010 9:17 am
When I was in school, we learned the math behind CS. This included optimization, formal proofs of completeness and complexity, etc..
These classes were required when I earned my Bachelor's but by the time I'd moved on to grad school, most of them had become 'optional' for non-honours students.
Sad.
PostPosted: Tue Aug 10, 2010 10:09 am
We did a bit of algorithmic analysis(Big O, Big Theta) etc and when I took the programming languages course we did talk in decent detail about how language designs play into efficiency(Eager vs Lazy evaluation). I think we might have a course named Optimization but i dont think it is even requisite for the Software Engineering concentration. I have yet to take the Compiler course which I imagine will include some of notions.
Ill have to dig up some supplemental instruction(a book) on the topic.
