It is currently Sun May 19, 2013 10:03 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: Daul Booting Help
PostPosted: Sun Jul 18, 2010 7:41 pm
Hello,
I have recently installed Ubuntu 10.04 because I wanted to see the new features and stuff. I wanted to dual boot Ubuntu and Windows XP. I installed Ubuntu and it worked fine and all but I can't boot into windows because grub does not appear before an OS boots. Windows XP is also not an option because I tried updating GRUB via Terminal and it did not find my Windows installation. If this helps; During installation I had to delete an older windows installation to install Ubuntu. I also tried adding windows to the GRUB menu from a site. Here is what happens when i type in the command sudo update-grub
Generating grub.cfg ...
Found linux image: /boot/vmlinuz-2.6.32-23-generic
Found initrd image: /boot/initrd.img-2.6.32-23-generic
Found linux image: /boot/vmlinuz-2.6.32-21-generic
Found initrd image: /boot/initrd.img-2.6.32-21-generic
“Adding Windowsâ€
PostPosted: Mon Jul 19, 2010 6:01 am
Do your windows partitions show up when you boot into Ubuntu under the places menu? What option did you choose when you installed Ubuntu? It should have detected that xp was already on the drive. It kinda sounds like you deleted the wrong/all windows installation when you installed Ubuntu.
You can hold down the shift key when you boot your computer to bring up the GRUB menu.
PostPosted: Mon Jul 19, 2010 6:31 am
This would be easier to just have you post what your grub.lst looks like and the results of an fdisk -l
PostPosted: Mon Jul 19, 2010 9:34 am
My windows Partition does show up in Ubuntu.
When i use fdisk -l it does not display anything in the terminal and there is no
grub.lst
PostPosted: Mon Jul 19, 2010 11:29 am
oh sorry...you probably need to do a sudo fdisk -l
As an example with mine...
title windows 1
rootnoverify (hd0,0)
chainloader +1
In your case, it's important see what's currently in your menu.lst.
The fdisk -l will not only tell you that the partition was there, but also where exactly it's at so you know what to put in the parenthesis so it points to the right place to boot from.
PostPosted: Mon Jul 19, 2010 2:29 pm
Just gotta add. If you want an easy solution Download Acronis Disk Director 11 Home. I have Win7. Win XP PRO, and Ubunto all installed. It has this program in it called Acronis OS Selector. It is so easy to use and it does it corectly. And you even learn from it. By seeing what it did to easily install.
http://www.acronis.com/homecomputing/pr ... kdirector/
There's the link....dont worry they have a DEMO version to check out. The free one's like GAG are hard to understand plus Win XP does not play with a MBR made from a Linux program. Hope this helps
PostPosted: Mon Jul 19, 2010 2:37 pm
Here is what shows up when I use sudo fdisk -l
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0xa0a0a0a0
Device Boot Start End Blocks Id System
/dev/sda1 65375 121480 450668544 83 Linux
/dev/sda2 * 2 65374 525108592 f W95 Ext'd (LBA)
/dev/sda3 121480 121602 975872 82 Linux swap / Solaris
/dev/sda5 2 65374 525108591 7 HPFS/NTFS
Partition table entries are not in disk order
craazziee8- I don't think you should advertise products on this forum
PostPosted: Mon Jul 19, 2010 2:42 pm
I dont work for them and I wasnt advertising I was answering your question. :roll:
His link is fine and that product would actually help you with your problem.
If you see a post that you think is suspect, please alert a moderator .. we'll take care of it if necessary. Thanks. :)
PostPosted: Mon Jul 19, 2010 2:48 pm
I'm sorry.
But the program won't work for me because I'm Using Linux and I can't get onto windows.
PostPosted: Mon Jul 19, 2010 6:14 pm
So I guess it bears to ask...are you seeing a windows choice for windows?
PostPosted: Mon Jul 19, 2010 8:21 pm
Million Club - 5 Plus*
grub.lst
What is contained in /boot/grub/grub.cfg ?
(Ubuntu 10.04 uses GRUB2 by default IIRC)
This is a snippet of my grub.cfg:
menuentry "Windows 7 Ultimate" {
        chainloader (hd0,1)+1
menuentry "Arch Linux (kernel26)" {
        insmod jfs
        set root=(hd0,3)
        search --no-floppy --fs-uuid --set 04f65c67-3aa5-49cc-aa00-5f8a6a3c7f96
        linux   /boot/vmlinuz26 root=/dev/sda3 ro
        initrd /boot/kernel26.img
PostPosted: Tue Jul 20, 2010 7:26 am
Here is my grub.cfg
# DO NOT EDIT THIS FILE
# It is automatically generated by /usr/sbin/grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
  load_env
fi
set default="0"
if [ ${prev_saved_entry} ]; then
  set saved_entry=${prev_saved_entry}
  save_env saved_entry
  set prev_saved_entry=
  save_env prev_saved_entry
  set boot_once=true
fi
function savedefault {
  if [ -z ${boot_once} ]; then
    saved_entry=${chosen}
  fi
function recordfail {
  set recordfail=1
  if [ -n ${have_grubenv} ]; then if [ -z ${boot_once} ]; then save_env recordfail; fi; fi
insmod ext2
set root='(hd0,1)'
search --no-floppy --fs-uuid --set e4a7ffb5-931a-4f22-9bd1-e78d5d988954
if loadfont /usr/share/grub/unicode.pf2 ; then
  set gfxmode=640x480
  insmod gfxterm
  insmod vbe
  if terminal_output gfxterm ; then true ; else
    # For backward compatibility with versions of terminal.mod that don't
    # understand terminal_output
    terminal gfxterm
  fi
fi
insmod ext2
set root='(hd0,1)'
set locale_dir=($root)/boot/grub/locale
set lang=en
insmod gettext
if [ ${recordfail} = 1 ]; then
  set timeout=-1
else
  set timeout=10
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'Ubuntu, with Linux 2.6.32-23-generic' --class ubuntu --class gnu-linux --class gnu --class os {
   recordfail
   insmod ext2
   set root='(hd0,1)'
   linux   /boot/vmlinuz-2.6.32-23-generic root=UUID=e4a7ffb5-931a-4f22-9bd1-e78d5d988954 ro   quiet splash
   initrd   /boot/initrd.img-2.6.32-23-generic
menuentry 'Ubuntu, with Linux 2.6.32-23-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os {
   recordfail
   insmod ext2
   set root='(hd0,1)'
   echo   'Loading Linux 2.6.32-23-generic ...'
   linux   /boot/vmlinuz-2.6.32-23-generic root=UUID=e4a7ffb5-931a-4f22-9bd1-e78d5d988954 ro single
   echo   'Loading initial ramdisk ...'
menuentry 'Ubuntu, with Linux 2.6.32-21-generic' --class ubuntu --class gnu-linux --class gnu --class os {
   recordfail
   insmod ext2
   set root='(hd0,1)'
   linux   /boot/vmlinuz-2.6.32-21-generic root=UUID=e4a7ffb5-931a-4f22-9bd1-e78d5d988954 ro   quiet splash
   initrd   /boot/initrd.img-2.6.32-21-generic
menuentry 'Ubuntu, with Linux 2.6.32-21-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os {
   recordfail
   insmod ext2
   set root='(hd0,1)'
   echo   'Loading Linux 2.6.32-21-generic ...'
   linux   /boot/vmlinuz-2.6.32-21-generic root=UUID=e4a7ffb5-931a-4f22-9bd1-e78d5d988954 ro single
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/11_Windows ###
menuentry “Windows XP″ {
set root=(hd0,0)
chainloader +1
### END /etc/grub.d/11_Windows ###
### BEGIN /etc/grub.d/20_memtest86+ ###
menuentry "Memory test (memtest86+)" {
   insmod ext2
   set root='(hd0,1)'
   linux16   /boot/memtest86+.bin
menuentry "Memory test (memtest86+, serial console 115200)" {
   insmod ext2
   set root='(hd0,1)'
   linux16   /boot/memtest86+.bin console=ttyS0,115200n8
### END /etc/grub.d/20_memtest86+ ###
### BEGIN /etc/grub.d/30_os-prober ###
if [ ${timeout} != -1 ]; then
  if keystatus; then
    if keystatus --shift; then
      set timeout=-1
    else
      set timeout=0
    fi
  else
    if sleep --interruptible 3 ; then
      set timeout=0
    fi
  fi
fi
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
I don't know if windows is a choice because I can't get GRUB to show up during boot. I hold the Shift key down but nothing happens. It just boots up normally.
I tried using the commend sudo update-grub and this is what happens
[code]phillip@phillip-desktop:~$ sudo update-grub
[sudo] password for phillip:
“Adding Windowsâ€
PostPosted: Tue Jul 20, 2010 9:07 am
You have this as your windows entry...
set root=(hd0,0)
chainloader +1
If that option isn't working I'm thinking you need to change root=(hd0,0) to root=(hd0,4).
Truthfully, I'm sort of puzzled how you ended up with the partitioning you posted above with an extended partition at the beginning where it is.
PostPosted: Tue Jul 20, 2010 9:16 am
But how can I get GRUB to display before an OS boots? I tried holding down shift as Ubuntu boots but nothing happens beside Ubuntu booting up to the login screen.
PostPosted: Tue Jul 20, 2010 9:24 am
Honestly, for all the trouble that this is causing you, I would just blow away the entire drive and repartition it properly with Windows and Ubuntu.
PostPosted: Tue Jul 20, 2010 12:34 pm
I would do that but I don't have an extra HDD to backup my data. And I don't have the money to buy an extra drive.
PostPosted: Tue Jul 20, 2010 2:28 pm
There should be some options in /etc/grub.d/default that you can change.
I rolled my own grub.cfg for grub2, so I'm only guessing.
The main issue is that there's a set timeout=-1 right at the end of the 00_header section
PostPosted: Tue Jul 20, 2010 3:00 pm
I got GRUB to show before Ubuntu boots and there is no Windows XP option.
PostPosted: Tue Jul 20, 2010 5:00 pm
Have you booted off the WinXP installation disk and tried to repair?
