It is currently Thu Apr 02, 2015 12:31 am
 Post subject: I had a crazy Idea
PostPosted: Mon Jul 05, 2010 10:26 pm
I have several Radioshack CBs, I have been thinking about putting
This"The CB"Realistic TRC-479 40channel:
into "My Tower"
PostPosted: Tue Jul 06, 2010 6:07 am
Team Member Top 250
Team Member Top 250
Sure why not. From the looks of it the radio seems similar in size of a 3.5" hard drive. Maybe a little bigger. Cool idea.
PostPosted: Tue Jul 06, 2010 6:40 am
actually it is smaller I manage to find the Dimensions
1-3/8 x 4-1/2 x 6-1/2 inches (HWD) (35mm X 115mm X 165mm)
http://support.radioshack.com/support_e ... 8/8781.htm
I was thinking of using a gutted out old CD drive for a metal shell and mount it into it sort of like a rack. The only thing I may have to do is recess it back alittle bit because of the door.
PostPosted: Tue Jul 06, 2010 11:41 am
This is my Idea:
I did this
To modify the part of the drive that has a magnet thing on the top of the drive that locks the disc to stable it.
The enclosure portion
The drive that I gutted was a LG CD-R/CD-RW Model CED-8080B
I mainly have to make a face for it and set it were it does not interfere with my tower door.
PostPosted: Tue Jul 13, 2010 10:27 am
Open the CB up and rewire the sound output to the front-panel line-in on your mobo or sound card.
Download Audacity and you can then record and manage the data.
PostPosted: Wed Jul 14, 2010 8:26 am
it has a mono phono plug on the back so it is already covered
PostPosted: Mon Jul 19, 2010 11:35 pm
Team Member*
Team Member*
That's a cool idea but what are you thinking of doing for a face plate to cover the space on the sides and to keep it cool in the drive enclosure? Does the CB even get that warm the you would need a heat sink for it? if you cut a small area near the hinge you should be able to mount the mic on the outside. while leaving it connected :)
PostPosted: Tue Jul 20, 2010 7:28 am
no the cb is a low end cb. also how can something Rx\Tx in 27Mhz range get hot
PostPosted: Tue Jul 20, 2010 7:44 am
as for a mic I have not got there yet and I have to order the plug for the ant.
PostPosted: Tue Jul 20, 2010 7:52 am
Team Member*
Team Member*
I was not sure if it would get hot but, I know that anything that has any kind of amplification can at the minimum get warm.
PostPosted: Tue Jul 20, 2010 11:05 am
This CB has no boosting function for the Signal that is another CB of mine but this one does not.
PostPosted: Wed Jul 21, 2010 1:42 am
Team Member*
Team Member*
okay, so are you planning on a front bezel?
PostPosted: Wed Jul 21, 2010 8:55 am
ya for the enclosure for the CB.
