It is currently Tue Jan 27, 2015 12:24 pm
 Post subject: Making a class visible to entire app in Visual C#.Net?
PostPosted: Wed Jun 30, 2010 6:58 pm
Is there a way I can make a custom class I made visible to the entire program that I'm writing (which consists of several Windows Forms and other class modules)?
I'm basically trying to get the "global variable approach" that was available in VB so that any form in my app can access those values.
PostPosted: Thu Jul 01, 2010 6:04 am
What are you trying to do?
If you have one Namespace you use across your entire application, you can. But then you lose the benefit of a tiered application and multiple namespaces.
http://msdn.microsoft.com/en-us/library/z2kcy19k(VS.80).aspx
http://www.csharp-station.com/Tutorials/Lesson06.aspx
 Post subject: Re: Making a class visible to entire app in Visual C#.Net?
PostPosted: Thu Jul 01, 2010 11:49 am
If you need the "global variable approach" in the first place, you should probably rethink your design.
global variables == tight coupling == bad
PostPosted: Thu Jul 01, 2010 12:52 pm
Yes, I know about this.
I actually found a way that works... create a static class and add static member variables to it. Then, if you create a public instance of the class in one of your class source-code files, the rest of the app should be able to see it. This is how I found out how to do it. Not the prettiest, but it does get the job done.
Basically, I needed to have a series of values that act as flags to tell me if a dialog box was closed (as in the user clicked either OK, Yes, No, Cancel, etc).
Can someone else think of a better way to get this value from another form via code?
Basically, Form1 opens Form2. Form1 waits until Form2 is closed. But I need to know which button (OK or Cancel) was pressed on Form2 so that Form1 can act accordingly without guessing or crashing the app.
PostPosted: Thu Jul 01, 2010 3:59 pm
Do you want a class that is accessible to the app or a set of values?
If it is the latter, you just want global variables.
PostPosted: Thu Jul 01, 2010 5:12 pm
Really just a set of global variables, but when I tried to just have global variables, c# would seem to complain that they needed to belong to a class. Whether it's a class or a set of variables, I don't care. I just need to be able to share values easily and quickly between classes and objects.
PostPosted: Thu Jul 01, 2010 6:04 pm
Yep, no global variables in C# apparently.
It seems you were on to the right idea. A static class (doesn't need to be instantiated and thus only one of each of its members will exist) with static (thus, unique) variables that is publically accessible. This should solve your problem.
Caveat: I know very little about C# and I did only about 4 minutes of google 'research' for this post. I could be so far out in left field that I left the stadium without noticing.
PostPosted: Thu Jul 01, 2010 10:02 pm
well, the static class seems to be doing it for me. Although this may not be the best approach, it is the fastest (and simplest that I've found). The app doesn't really deal with a lot of data so there really is no data to be screwed up. It just takes SQL commands and sends them to the SQL server and then displays the results in a textbox. That's all.
PostPosted: Fri Jul 02, 2010 4:41 am
Jipstyle wrote:
It seems you were on to the right idea. A static class (doesn't need to be instantiated and thus only one of each of its members will exist) with static (thus, unique) variables that is publically accessible. This should solve your problem..
Global variables are evil. Needless to say. A static class is similar in behavior as a VB module (last I checked, it's been a while and I don't use static classes).
The ShowMessageBox() method returns a DialogResult enum. Use that instead. If you're trying to capture the output of a form, why don't you try attaching an event in Form1 from Form2? That or create a property that returns the message it needs to return.
PostPosted: Fri Jul 02, 2010 6:43 am
This.
What you're describing is simply a modal dialog box. If all you care about is what button was clicked, the DialogResult enum DJSPIN80 mentioned does exactly what you want. If you want a form that's not modal and need to know when someone clicks a button you'd need to add event handlers from Form1 to the button click events in Form2.
PostPosted: Tue Jul 06, 2010 3:42 am
Further you could have any number of statuses returned from that Enum if you create a custom dialog form and set your buttons to either return the DialogResult value you are looking for, or set the Form.DialogResult property.
