It is currently Sun Mar 29, 2015 9:27 pm
 Post subject: display mysql console output into a textbox using VS.NET
PostPosted: Thu Jul 01, 2010 8:29 pm
Is there a way to take the output that MYSQL generates (when you run a query, for example "SELECT * FROM EMPLOYEES" and pipe or transfer that output (the laytout of the table with the matching values in table form) into a textbox in a .net application (either VB.Net or VS.Net)
I already know how to use the MySql Connector for .Net, I just want to be able to get the same output that you would from Mysql using the command prompt into a textbox.
I'm trying to create a Windows app that will do the same functionality as the MYSQL command line system.
PostPosted: Fri Jul 02, 2010 3:33 am
http://prequel.codeplex.com/
MySQL has official GUI tools btw...
PostPosted: Fri Jul 02, 2010 2:59 pm
Thanks. I'm aware that MySQL has what I'm trying to do, but part of this is a learning experience for me in C#. It's not something I plan to give out or sell, but may decide to use parts of it in my future programs if they deal with MySQL.
