It is currently Sat Apr 25, 2015 6:54 am
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu May 20, 2010 8:33 pm
That looks really good. I am thinking of making my frame out of wood and plexy glass later thus summer but I still have to make a design.
PostPosted: Sat May 22, 2010 8:24 pm
The performance PC parts are ordered! WOOT!
Order Confirmation from Performance-PCs.com Performance-PCs.com
spacegy4,
Thanks for shopping with us today!
The following are the details of your order.
Order Number: 163054
Date Ordered: Sunday 23 May, 2010
Click here for a Detailed Invoice
Products
8 x120 mm Fan Grill - Chrome (GRILL120) $11.92
1 xCoolJag Coolest Mini LED Flash Fan - Programmable 120mm Fan - Retail Package (EF4-120)
Sleeve Color Black
Heatshrink Color Black$19.95
1 x*** NEW *** NZXT Single Sleeve 8-Pin Motherboard Power Extension 10" - Black (CB-8P) $6.99
2 xLamptron Pre-Wired Vandal Switch Cable Assembly (Spade-Style) - Momentary - Sleeved (LAMP-MOM-SW-WIRE)
Cable Stock cable - Sleeved
Sleeve Color Black
Heatshrink Color Black$9.90
1 x3 Pin to 4 Pin Fan Adapter Sleeved (3TO4FAN)
Sleeve Color Black
Heatshrink Color Black$3.95
1 xLian Li Replacement Mini Speaker (LL-SPEAKER) $2.95
1 xMNPCTech Billet 120mm Fan Grill - Silver (MNPCTECH-120GRILL-SL) $22.99
1 xDrivebays: For 3 x 3.5" HDD (Internal) (PPC-H311) $9.95
7 x120 mm Fan Grill - Black (GRILL120BK) $13.93
3 xMitron Shouldered Thumbscrews Anodized Aluminum (Set of 10) - Silver (MT-TSCREWS-AL-SL) $11.97
1 x*** NEW *** NZXT CB-24P Single Sleeved M/B 24Pin - Black (CB-24P) $9.99
7 x*** NEW *** Yate Loon CLEAR 120mm Medium Speed Silent Case Fan with Red LED - D12SM-124R - Sleeved (D12SM-124R)
Cable Convert to 3-Pin only (Cut off extra connectors) - Sleeved
Sleeve Color Black
Heatshrink Color Black$48.65
1 x*** NEW *** MNPCTech BEEFY Rubber Case Feet (MNPCTECH-CFR) $9.99
1 x*** NEW *** NZXT Single Sleeve 6-Pin VGA (PCI-Express) Extension 6" - Black (CB-6V) $5.99
2 xSlimline SATA Cable w/ 20" 7-Pin Serial ATA Female & 4" 4-Pin(5V) molex Power Connector (SLSATAF20) $11.90
2 xVandal Resistant Switch - Silver (VAN-SW-22) $10.50
1 x*** NEW *** NZXT Single Sleeve 6-pin to 6+2-pin VGA Extensionr 6" - Black (CB-8V) $5.99
5 x3-Pin Y-Adapter Cable 6" Sleeved (3PYSPLIT-6)
Sleeve Color Neon UV Red
Heatshrink Color UV Red$19.75
1 xAPEVIA Case Fan Screws - 40 Pieces (FS-01) $3.99
Sub-Total:$241.25
United Parcel Service (1 x 16.55lbs) (2nd Day Air):$48.69
Total:$289.94
PostPosted: Wed May 26, 2010 10:55 am
very nice work, You're lucky to have access to plasma cutting machines, I have plasma cutters which are fairly expensive but the machine component that handles the exact program is like over $50,000 (one in video is probably around the 150k mark) so the mods i've done where I have to cut 80 / 120 mm fan holes I always have to manually mark tangent lines and cut for like 1 cm at a time making the fan hole like 70mm or 110 mm then get a rotary sander for the rest.
Looks really nice in the end GL on the assembly.
PostPosted: Wed May 26, 2010 10:59 am
its a laser cutter. Not a plasma cutter.
Also: The PPC Parts got here! YAY! pix will come
PostPosted: Wed May 26, 2010 12:46 pm
And here is all the awesome hardware from PPCs!
PostPosted: Wed May 26, 2010 2:32 pm
Monkey Federation (Top 10)*
Noice
PostPosted: Wed May 26, 2010 3:58 pm
Million Club [PC]
Million Club [PC]
Very nice, now get to work! I want to see some more pics. :P
PostPosted: Wed May 26, 2010 7:54 pm
Im looking forward to seeing what you got for text on that fan- need moar pix :D
PostPosted: Thu May 27, 2010 11:18 am
Laser and plasma cutters are the same, laser cutters use superheated gases in combination with a laser diode to direct the gas towards a finite point, but after the gas is superheated, it falls under the category of plasma, which is why I called them plasma cutters. Generally lasers are associated with energy from lights which isnt the main component of "laser cutters" but it is the superheated gas A.K.A. plasma
PostPosted: Thu May 27, 2010 12:53 pm
The cutter was a carbon laser. Not a plasma cutter. They are not the same.
This helps explain it:
http://www.teskolaser.com/laser_cutting2.html
if it was a plasma cutter I wouldn't be able to be near it without safety glasses. Also note the gap between the laser and material is much greater than it would be for a plasma cutter. The cutting laser does use light as it is truly a CO2 gas laser.
PostPosted: Fri May 28, 2010 3:57 pm
and moar pix!!!!!!!
motherboard tray hack sawed and bent to fit into case securely using sheet metal screws I will be screwing it in tomorrow. I will also be bolting the 2 main frame pieces together.
A difference you may notice is that I took a hack saw to the upper frame piece to make clearance for the motherboard tray
alternate view
PostPosted: Mon May 31, 2010 12:33 pm
Major progress!
The motherboard tray is now secured to the case with 3 screws and 2 L brackets with 2 screws each.
PostPosted: Wed Jun 02, 2010 5:18 am
UPDATE!
I also found a way I will be able to put digital camouflage on the outside of the case without paying a bloody fortune for an airbrush job. Plastic parts for the front panel and windows are being ordered today.
PostPosted: Wed Jun 02, 2010 2:08 pm
Its really coming together nice. Starting to look like it might turn into a case! :D
PostPosted: Mon Jun 07, 2010 9:19 am
The external disk drive and hard drive cages are now secured!
PostPosted: Wed Jun 16, 2010 10:43 am
win!
PostPosted: Wed Jun 16, 2010 9:28 pm
Million Club [PC]
Million Club [PC]
WOW! That's just awesome! Great work! And... NICE rig in it too!
PostPosted: Wed Jun 16, 2010 10:17 pm
Nice, did you do the painting yourself? If so, how did you do the digi-camo? This looks great man, do you have shots from other angles around the case?
PostPosted: Fri Jun 18, 2010 5:00 am
sorry about the reflection. I will get a better pic soon. You can see the Asetek/Corsair H50 LCS.
here is a pic with it on. I will take pics of it in the dark showing how awesome the lighting is and the 7in screen I have installed in the front when I get the chance.
PostPosted: Fri Jun 18, 2010 9:16 pm
How did you get the military texture on it? Was that a decal?
Send that in to CPU's monthly modding contest, it has a quite good chance of winning!
