It is currently Sat Apr 25, 2015 11:15 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2, 3  Next
 Post subject: Case from scratch (UPDATE: 6/16 COMPLETED)
PostPosted: Wed May 05, 2010 11:24 am
This is my first major modding project. I'd done enough cutting holes in things, rigging up lights and etc that I decided that what I would do next is build a case pretty much from scratch out of aluminum. I will be welding the major framework and using screws to hold the panels on. The framework will be constructed out of 1"x"1 1/16in thick square tubing. (even though extrusion is shown in the drawing I am using sq tubing)
Here is a back quarter view.
I have designed the entire case using Autodesk Inventor Pro 2011
I liked the vertical motherboard mounting style of the raven 2 so I decided to implement that in my design.
I divided the case into thermally isolated chambers for the motherboard, power supply and optical drives, and hard drives.
I will be using a 7in MIMO USB monitor which I have integrated into the case.
PostPosted: Wed May 05, 2010 12:04 pm
Just got home and was greeted with boxes of my aluminum tubing and sheet metal. I will start cutting all the parts out tomorrow.
PostPosted: Wed May 05, 2010 2:37 pm
Lookin' good like it should!
PostPosted: Mon May 10, 2010 10:21 am
no comments? feedback?.... anything?
PostPosted: Mon May 10, 2010 11:59 am
Monkey Federation (Top 10)*
We're waiting for pictures.
PostPosted: Sun May 16, 2010 12:17 pm
As an engineer I feel like that's a really advanced case unless you have all of the right tools, as in an entire functioning machine shop or access to good NC programmers. But Good luck!
If you can I would recommend installing ceramic plates to isolate sectors of the PC like you wanted to do, ceramic has a very low thermal conductivity where as aluminum is pretty high, meaning that your idea of separating out the sections could be moot if your using aluminum (depending on the thickness, but regardless ceramic divisions would be better. If you don't know how to work with ceramic that well, use stainless steel for the divisions which is still has MUCH less thermal conductivity as aluminum does.
Acrylic glass is another better option that's easier then ceramic and probably better. But can be more fragile then ceramic plates.
PostPosted: Sun May 16, 2010 4:51 pm
The high school has a machine shop which I used to band saw the extrusion to size. I am going to get a local machine shop to laser cut the plates.
Those who were waiting for pictures... well here they are!
The 2 frame pieces are now welded:
PostPosted: Sun May 16, 2010 6:42 pm
Million Club [PC]
Million Club [PC]
Looking great so far! I don't see anything you need to improve atm.
PostPosted: Mon May 17, 2010 7:42 am
Looks very nice.
What are the dimensions of the case?
PostPosted: Mon May 17, 2010 12:07 pm
dph1077 wrote:
Looks very nice.
here they are:
PostPosted: Mon May 17, 2010 2:59 pm
Sweet! That looks like it is going to be heavy as fawk!
PostPosted: Mon May 17, 2010 3:52 pm
actually not really. The frame you see in the picture weighs only about 8 pounds. Its 1/16 inch thick wall square tubing. Really light. But the plates, screws, hardware and etc will add some.
Wednesday I'm going to the shop to watch the CNC laser cut out the plate material. I will get some pictures of that
PostPosted: Tue May 18, 2010 11:11 am
Wow, that's really nice work so far, seeing the specs is nice as well, hopefully you don't do pure aluminum or at least do certain parts in stainless steel or ceramic or acrylic.
BTW nice welds if you did those /respect
PostPosted: Tue May 18, 2010 11:13 am
I didn't do the welds. Sorry for not mentioning that. They took a professional 4 hours to do.
PostPosted: Wed May 19, 2010 6:16 am
after school today I get to watch a CNC laser cut out the aluminum plates out.
I will definitely post pics of it.
PostPosted: Wed May 19, 2010 1:13 pm
The plates have all been lasered. Here are some pics of the hot action.
I'm also uploading a video: http://www.youtube.com/watch?v=qd0PaFXRxIE
PostPosted: Thu May 20, 2010 8:37 am
Team Creamsicles
Team Creamsicles
Man, those machines are so damn cool! can't wait to see more pics :D
PostPosted: Thu May 20, 2010 11:32 am
I took the plates and just tried laying them out on the frame by hand.
here are pics:
PostPosted: Thu May 20, 2010 3:13 pm
Looks like a couple of them got tweeked.
PostPosted: Thu May 20, 2010 4:12 pm
yeah some got tweaked in shipping. Oh well. Its not too bad
