It is currently Fri Mar 27, 2015 10:04 pm
 Post subject: Born to Kill Silverstone Raven RV02
PostPosted: Mon Mar 22, 2010 7:04 am
I have start this project a few days and i'm here too share with you guy's i hope you like what i already do and enjoy!
Born to Kill Silverstone Raven RV02 By Hardmodding Team
Hardware:
Case: Silverstone Raven RV02B-W
Cpu: Intel Core i5 750
Motherboard: Asus P7P55D
Mems: Gskill DDR3 PC12800 Ripjaws 4GB
GPU: Sapphire HD4770 512MB -.-"
PSU:Fractal Design Newton R2 800W
Watercooling:
Liquid: Feser One UV Blue
Res.: EK-Multioption 150mm Rev.2
Gpu Block: EK-VGA Supreme - Acetal
Cpu Block: EK-Supreme LT - Acetal
Tubo: Feser 13/10mm - UV light blue, 2,5m
Fittings: Bitspower matt black
Fittings: 45º Bitspower matt black
Just to warm up a bit :mrgreen:
Image Image
Image Image
Image Image
Image Image
Image Image
Image Image
Image Image
Image Image
Image Image
Image Image
Image Image
Note: The orange sleeve is not for this project :p
Image Image
:eek: :eek:
Image Image
Image Image
Image Image
Image Image
Image Image
Image Image
Image Image
Image Image
Image Image
Image Image
Image Image
Image Image
Image Image
Image Image
Image Image
Image Image
Image Image
Final photos soon :p
PostPosted: Mon Mar 22, 2010 7:12 am
Million Club [PC]
Million Club [PC]
That's a great water-loop and amazing cable management! Individual sleeving is so labor-intensive. Are you going to do any mods to the case?
PostPosted: Mon Mar 22, 2010 9:02 am
Thanks for the reply!
About the mods to the case i don't think because it's to a customer and he dont wanna change it!
PostPosted: Tue Mar 23, 2010 1:31 pm
Team Member Top 1000
800w power supply
4770
wut
PostPosted: Tue Mar 23, 2010 1:36 pm
Million Club [PC]
Million Club [PC]
bbecker42 wrote:
800w power supply
4770
wut
mistype. It was a 5770. Still a lolwut though. :lol:
PostPosted: Wed Mar 24, 2010 12:52 pm
I agree with what Spartacus said, amazing cable management in the case, I also own that case but without the WC so far its been a great case. Funny though how some say its a mid size case and others say its a full tower.
PostPosted: Sun Apr 04, 2010 7:36 am
Just a small update sponsored by Mnpctech!
3x 120mm Steampunk Radiator or Fan Grill
Just want to say thank you Bill and Mnpctech by sponsoring us whith one Steampunk rad grill in this project!
More photos incoming today! :P
PostPosted: Sat Apr 10, 2010 9:38 am
A new update time ! Some of the cable are not ready because i will change it, like SATA cables to 90º and some other stuff's incoming to the project ! I hope you like it
PostPosted: Sat Apr 10, 2010 2:29 pm
Team Creamsicles
Team Creamsicles
Man that is such a sweet rig! And theres nothing wrong with an 800w PSU in that rig. I never understood the reasoning in getting a PSU that just meets the needs of the setup, and no more. I always think having plenty of head room for power is very inportant. Plus you can add things to a certain level and not worry about if you have anough juice for it.
How did you get a sponsorship?
PostPosted: Sat Apr 10, 2010 7:26 pm
Million Club [PC]
Million Club [PC]
Then again... he could add 20HDDs and 3 more 5770s and a CPU with a higher TDP and still not even come close the full output of the PSU... or he could have saved $100 and gotten a 500W. I don't understand your reasoning really, a 400W with a 5770 is plenty of power. An 1156 system with 2 HDDs and a 5770 pulls about 300W under 100% load. That's a lot of headroom for all the hard drives and fans you can stuff in there. Not another 5770, but move up to a 500W and another 5770 is now well under the output of the PSU.
PostPosted: Sat Apr 10, 2010 8:02 pm
That case looks amazing. on the cable management on the back side did you just rivet the cable holders?
PostPosted: Sun Apr 11, 2010 12:05 pm
Team Creamsicles
Team Creamsicles
Just saying there is not a thing wrong with having plenty of headroom with the PSU, it's the single most critical part of a power user or enthusiasts build. You get a high quality one and it will last through several upgrades. You have the extra $ to put into it, no reason not to do it. :wink:
PostPosted: Sun Apr 11, 2010 11:42 pm
sukhoi342 wrote:
On the cable management on the back side did you just rivet the cable holders?
It would appear he used hex screws, possibly torx, but look more like hex. I envy this system, the overall artwork that's gone into this project is utterly awesome. I thoroughly applaud you.
PostPosted: Mon Apr 12, 2010 9:43 am
soul train always does awesome work.
PostPosted: Mon Apr 12, 2010 10:05 am
The cable management in this case is flawless and the sleeving looks great. I would do that to my psu, but My case is windowless
PostPosted: Mon Apr 12, 2010 7:20 pm
The way all builds should be, if we care about them that much. It's not hard, and is what the workshop is for: Inspiration of what is possible.
The problem is not actually doing it and just watching others do good work. Raise the bar.
PostPosted: Tue Apr 27, 2010 8:04 pm
That thing looks GREAT! Very nice cable work, wish my case had all those brackets.
PostPosted: Wed Apr 28, 2010 3:42 am
Not sure I am a fan of the way the radiator is set up.... seems like you'd want more air getting through it.
Also, don't you want the CPU cooled first? I know it isn't necessarily practical but I would think having two loops would be ideal. One for CPU and one for everything else.
PostPosted: Sun May 02, 2010 7:08 pm
Our very own Chumly has pointed out many times that the fluid in a cooling loop normalizes over time, so it doesn't matter where a certain block is in the loop.
PostPosted: Mon May 31, 2010 5:25 pm
Team Member Top 250
Team Member Top 250
I would like to point out a site for you.
Million Dollar PC
Your's definitely belongs there.
