This is a guide to set up the GPU Client. I am not responsible for damage resulting to your computer for following this guide.
This guide will help you set up one gpu client. If you have two or more gpu's, then you also will need to look at
this.
Requirements:
computer with one of the following GPU's:
-Nvidia Geforce 8 series GPU or newer
---or---
-ATI / AMD HD2xxx or newer
recent cpu
at least 512 mb RAM
a power supply that can power all of those GPU's
Windows xp / Vista / 7
Step 1. Download the GPU client
here
Step 2. Install the GPU client. There should be an installation wizard to follow.
Step 3. It should create an Icon during the install process. Click that icon.
A window should pop up with "username", "team", and "passkey" boxes.
ignore the "passkey" box.
Put a username of your choice into the "name" box. It's a good idea to keep it the same as your forum name.
Remember to put "11108" into the "team" box
Step 4. Click OK.
It should now be running.
Right click the Icon in the System Tray for more options, such as "pause" and "quit".
Happy folding!
Ted
Pictures 2 & 3 are credit to Pande Group GPU guide. Picture 1 credit to me
