It is currently Sat Apr 25, 2015 7:10 am
 Post subject: MySQL
PostPosted: Thu Feb 18, 2010 11:01 pm
Team Member Top 250
Team Member Top 250
Ok I am having a very hard time setting up MySQL for a LAMP machine. I have already installed PHP and Apache with no problems but as soon as MySQL is finished installing, I execute the following command, mysql -u root, but I get this error:
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: NO)
So I try to prompt for a password with mysql -u root -p. I type in the root password and I get this:
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: YES)
Can't figure out whats wrong here, cause I installed MySQL minutes before.
PostPosted: Fri Feb 19, 2010 10:24 am
What did you do to install it? What OS? More info?
PostPosted: Fri Feb 19, 2010 12:49 pm
Team Member Top 250
Team Member Top 250
sudo apt-get install mysql-server
Its running on Ubuntu server.
PostPosted: Wed Mar 31, 2010 3:21 am
When MySQL completes and releases the 5.x version of its product it will have matched and in some cases surpassed the major databases in basic SQL compliance and functionality. MySQL 5.0 is in advanced alpha testing. The three key add ons to 5.0 are stored procedures using the SQL 2003 standard syntax, cursors and a complete set of views. The performance enhancement include better support for in MEMORY tables plus added indexing options for user control. as well 5.0 will settle VARCHAR implementation differences, in fact moving closer to the defato standards.
