It is currently Sat Feb 28, 2015 8:46 pm
 Post subject: C program help reading file from stdin
PostPosted: Mon Mar 15, 2010 5:34 pm
Ok, i'm working on a program in C to read in a file given by user and print it out to screen along with its size(for now). I haven't done very much C at all and am still trying to figure out all the pointers and stuff.
Q1. what do you recommend for C debugging? i've heard just using ddd or gdb is the best thing, but i've tried messing around with it and seems quite annoying. any good alternatives?
Here is the code:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
static char *prog;
int main(int argc, char *argv[])
   printf("Welcome to the Word Length program\n");
   prog=argv[0];
   char *inpFile=argv[1];
printf("1");
   FILE *inStream=stdin;
   if (strcmp(inpFile,"-")!=0)
      if ((inStream=fopen(inpFile,"r"))==NULL)
      fprintf(stderr,"%s: <input>\n",prog);
      exit(1);
printf("2");
   char *word; //I believe my problem is here
   int n=0;
   while(scanf("%s",word)!=EOF)//and here
printf("2.5");
      word=strtok(word," .,;:!()/#");
printf("3");
   n=sizeof(word);
   printf("The word %s has size %d \n",word,n);
   free(word);
printf("4");
   fclose(inStream);
   return 0;
The output:
12
after that it just sits
q2. I need to use char *word; is there a method for scanning in words with the pointer? i know scanf works with char[20] or w/e size but not with the pointer. any advice?
thanks
PostPosted: Mon Mar 15, 2010 7:50 pm
Million Club - 5 Plus*
On Windows, Visual Studio has the best debugger I've ever used. On *nix, I'd just use gdb -- it's not that hard to use.
What OS are you running on? I got the code to execute to completion as is by entering ^D (aka EOF) on stdin under x86_64 Linux. However, when I went to enter some input, it failed at the strcmp because word == NULL.
What you need to do is read in a char[BUFFER_SIZE], process that, and then get the next buffer worth of characters until the end of the file. BUFFER_SIZE should be a number of characters, usually at least 80.
