It is currently Wed Jun 19, 2013 6:55 pm
 Post subject: Mod my HAF 932
PostPosted: Sat Feb 13, 2010 9:58 pm
Team Member Top 1000
http://image.ohozaa.com/il/8ks19.jpg
This HAF makes me nerdgasm. How is such a good paintjob performed. Because mine could really use a paintjob.
PostPosted: Mon Feb 15, 2010 10:54 am
Sick rig. I like mine moar. White on red just doesn't work.
PostPosted: Mon Feb 15, 2010 1:37 pm
I want to paint mine like that, that one in the link isnt mine unfortunately.
PostPosted: Mon Feb 15, 2010 6:01 pm
Team Member Top 250
Team Member Top 250
Wow that's an amazing rig. I don't know if its me, but that picture took way to long to download. Anyway, that is a damn fine case. I like the red on black because the red doesn't seem to overpower the black on a stock case.
PostPosted: Mon Feb 15, 2010 7:25 pm
In that case (har har har), I'd just go with this and be done with it. Not to mention the awesome AMD Dragon on the window too.
PostPosted: Mon Feb 15, 2010 8:54 pm
I really like bbecker42's link that is a really clean simple work of art. Except for the CM shield on the front all the "Me To" crap is gone and the paint work appears to be smoot as a baby's butt. As neat as those side windows are done I could almost reconsider not having them.
PostPosted: Tue Feb 16, 2010 5:50 pm
I would but I have an Intel proc and I already own the HAF. I just want to know how to make mine like that.
PostPosted: Tue Feb 16, 2010 6:15 pm
Team Creamsicles
Team Creamsicles
Easiest and most expensive way to do it is see if your local car paint shop will shoot your case for you. Call around and see if anyone has any experience with computer cases, or if they are willing to at least talk to you about it.
Otherwise, get yourself some cool poof can, masking tape, disassemble that sucker and go to town!
PostPosted: Tue Feb 16, 2010 8:02 pm
i painted the inside of my HAF932 with PlastiDip. works great so far. not as shiny as NORMAL paint, i suppose, but if you mes sup, peel/rub it off when it dries and try again.
http://www.plastidip.com/
comes in a variety of colors, and as a tip, might not want to put more than 2 coatings..i put 4, and when i stuck the PSU bracket back in, it stuck to the bottom inside of the case, so when i had to remove it temporarily, it peeled some off.
PostPosted: Wed Feb 17, 2010 8:33 am
What's wrong with White on Red? It looks like a old Ford Mustang :lol:
PostPosted: Wed Feb 17, 2010 8:33 pm
meh. It just doesn't go with the haf styling. I can't say why, but it doesn't.
PostPosted: Wed Feb 17, 2010 11:35 pm
Honestly, with it being a High Air Flow design, I think it'd be awesome to see it with a custom "clouds in the sky" paint job. It only seems appropriate if you ask me.
PostPosted: Thu Feb 18, 2010 9:46 am
I like that colour scheme ... looks very stormtrooper.
PostPosted: Thu Feb 18, 2010 5:28 pm
Million Club
Million Club
where can i get that backround?
PostPosted: Thu Feb 18, 2010 6:16 pm
That was discussed in that thread. Just scroll down. All the way.
PostPosted: Thu Feb 18, 2010 7:47 pm
OK well being extremely poor(ActionPC wont hire 15 y/o's) I dont think automotive paint is a reasonable way to get my case painted.
How could I paint it so that the paint I do looks like what came with it(like same shininess and color)?
PostPosted: Sun Feb 28, 2010 9:05 pm
Here is a pretty comprehensive guide to painting a case- http://case-mods.linear1.org/case-mod-101-how-to-paint-your-computer-case-part-1/
If you have the patience, this shows you how to get a better finish than any stock case would have. Otherwise, you can skip the wet sanding steps and have a pretty nice finish also.
