It is currently Fri Mar 27, 2015 7:59 am
 Post subject: Mystery Firefox Addons
PostPosted: Wed Feb 17, 2010 6:34 pm
Found 2 Extensions in Firefox I don't recognize, both named Java console, both no options or uninstall buttons.
Any ideas as to what they are?
PostPosted: Wed Feb 17, 2010 7:15 pm
https://addons.mozilla.org/en-US/firefox/addon/141
PostPosted: Wed Feb 17, 2010 7:39 pm
not it.
 Post subject: Re: Mystery Firefox Addons
PostPosted: Wed Feb 17, 2010 8:10 pm
They are plug-ins/addons for Java when its installed (so you can use it in Firefox). Disabling/uninstalling them will bork anything that would use Java to work.
For example, you wouldn't be able to use this speedtest.
PostPosted: Wed Feb 17, 2010 8:23 pm
The speedtest works, and they are disabled. It sounds like you're thinking of the Java Platform plug-in, but these are add-ons, and I don't recognize them from before. Are you sure i should trust these addons, i know i can trust the plug-in.
PostPosted: Wed Feb 17, 2010 8:29 pm
Actually, my bad..retracting my statement about breaking Java. They won't do any harm as they allow you to monitor and debug running applets. They won't do any harm but it would probably be best to just leave them as they are.
PostPosted: Thu Feb 18, 2010 3:41 pm
Ok, thanks!
