It is currently Fri Mar 06, 2015 4:04 am
 Post subject: Recording Composite Video?
PostPosted: Fri Feb 12, 2010 5:19 pm
I recently bought a shiny new Hauppauge WinTV-HVR-2250 (newegg link: http://www.newegg.com/Product/Product.a ... -_-Product). Everything works great, except I can't find a way to record video from the composite inputs. Windows Media Center will do it if I tell it I'm recording from a Satellite or Cable box, but when I select that option, it tells me to set up a remote, which I don't have. There is no way to skip remote setup. Someone made a dummy remote driver to get past this screen, but its 32 bit only, and I'm running 64 bit Windows 7. So, with MCE out, I turned to the WinTV application that I thought came with the card, only to find that I got the OEM version of the card.
I have tried some free video recorders, but none of them seems to record the audio off of my card, they recorded video only. Roxio Creator 10.2 records fine, but I can't watch it recording (in other words, I can't see it recording, but I can watch the saved video.)
So, I'm stuck. What should I do? Does anybody know of any way to get past the screen on Windows Media Center? If not, then what software should I use to record my composite inputs? I want to convert VHS tapes to DVD's, and most of what I'll be working with is home videos, so I want to preserve as much of the quality as possible. That's why it is important that I use composite inputs as opposed to a coax cable.
If Microsoft had a clue, I wouldn't have this problem in the first place.
Thanks for your help.
PostPosted: Sat Feb 13, 2010 11:04 am
Not an exact solution, but since you're converting VHS, why not just use the coax input?
Looking at the MCE docs on Hauppauge's site, I don't see where it would ask you for this. Personally, I'd probably hit the local thirft store or wal-mart and find a cheapo universal to use if you really need a remote.
PostPosted: Sat Feb 13, 2010 11:45 am
I don't really want to use coax because I'm worried about video quality loss. I'd prefer to use composite inputs.
Yes, it appears that I might just have to give in and buy a remote. Its either that or spend $10 on WinTV, which seems to get awful reviews.
PostPosted: Sat Feb 13, 2010 12:06 pm
I can't imagine you see a whole lot of loss. You are dealing with tape after all.
Were you playing a tape or displaying TV from the VCR tuner when you setup the analog tuner in Media Center?
PostPosted: Sat Feb 13, 2010 12:19 pm
Actually, I haven't used the VCR yet. I've been using a Plug and Play TV video game to get my connections up and running, as it shouldn't make a difference as long as there is video. I can get a working coax connection, but I want to make sure that as the tapes get converted, I get the best picture possible. Some of the tapes are home videos in bad shape, the last thing they need is more distortion through the conversion.
I also have an analogue video camera with mini tapes that need converting. If I can't plug it into the composite inputs on my card, then I'll have to run it thought the VCR too, a less than ideal option for archiving.
A Google search for IR Hardware Not Found will show that others have the same issue. I have pretty much given up on Media Center at this point.
PostPosted: Sat Feb 13, 2010 1:00 pm
One would think...although I would wonder the game is sending something that MCE would regognize (and how much need is there for someone to actually record a video game)
PostPosted: Sat Feb 13, 2010 1:38 pm
No, there isn't a reason for me to record my game, but its easier to move around as I try to figure out everything than a VCR. And I'm fairly certain that its not the game, as other people have the same issue. As I said, its so bad that a dummy remote driver was developed, but its 32 bit only.
The problem here is Media Center only supports composite inputs if you tell it that you are recording a set top cable or satellite box. There is no simple composite input option.
Sage TV works fine, but its $70 once the trial expires. If I must, it would be cheaper for me to get an IR blaster and remote to satisfy Windows Media Center's demands. (I just don't like it when my computer tells me what I do and do not need. That's why I don't like Macs.)
PostPosted: Sat Feb 13, 2010 9:09 pm
Million Club [PC]*
Million Club [PC]*
Don't give up on Media Center in general - just give up on it for this use. MC is not (and never has been) meant to be used as a video-capture app. That's what a proper capture card (and software) is for. ;)
You might be able to get a proper capture app to use the A/V inputs on your card, just not MC (at least, not without a lot of pain.)
* Exception: if you set up MC to use a STB (proper setup - using IR hardware, and you actually run an STB for TV use), then you can change the inputs when you want to archive a tape, and do a manual recording. However, the quality will be no better than the source material (especially for your already-degraded tapes.) No means to clean up the material. Again, here a proper vidcap / editing app would be better.
If you try getting the IR hardware, and then re-running TV Setup with your VCR as the STB, it'll still fail - MC won't be able to execute a channel change on the VCR (no built-in IR codes.) Manual code entry is, ah, iffy sometimes.
MC is a great DVR (and, only got better with each iteration), as that's what is was designed to be - a DVR and entertainment hub. Not a vidcap app.
PostPosted: Sun Feb 14, 2010 6:27 am
Ok, so seeing as my card didn't come with software, what should I buy to capture video from it?
I don't want to spend a whole lot, but if software is what I need, I will buy it.
Scrolling through Newegg, it doesn't seem as though there is a whole lot of software that advertises capture from a tuner card. Also, I need a trial or demo version to be available so I can make sure it works before I buy it.
PostPosted: Sun Feb 14, 2010 10:36 am
Million Club [PC]*
Million Club [PC]*
Give VirtualDub a try. If it sees the A/V inputs on the tuner, great. If it doesn't, nothing but a few minutes lost - it's a free app.
PostPosted: Sun Feb 14, 2010 2:31 pm
VirtualDub is EXACTLY what I have been looking for.
A thousand hearty thanks to you.
PostPosted: Tue Feb 16, 2010 8:41 pm
Million Club [PC]*
Million Club [PC]*
You're welcome. I take it that it worked?
PostPosted: Fri Feb 26, 2010 4:14 pm
Yes, it worked great. Now the problem is getting the video onto DVD (see my AVStoDVD thread.)
