It is currently Sat May 25, 2013 5:26 pm
 Post subject: cheapest mac for creating iPhone apps?
PostPosted: Mon Feb 08, 2010 9:01 pm
I read you have to have a mac to make iPhone apps,so I was planning on just getting a mac mini.....but I at first thought I want to build a hackintosh with win 7.... but I heard you have problems trying to get apps certified thru the app store without a real mac pc
PostPosted: Wed Feb 10, 2010 10:48 am
Yes, these are all true.
If you aren't comfortable doing the research yourself, cross the Hackintosh off your list. At some point, you will encounter a problem that will require lots of googling and forum searching.
Given that, a Mac Mini is the cheapest alternative. In order to run the iPhone SDK, you need an Intel-based computer running some flavour of MacOSX.
Some people have had success running OSX in a VM, though .. you could try that first since it doesn't require spending any money.
 Post subject: ok
PostPosted: Wed Feb 10, 2010 11:31 am
ok, thanks for the info, I'll look into the vm also
PostPosted: Wed Feb 10, 2010 2:16 pm
You could also get a used or refurbished mac and save a bit of cash.
PostPosted: Fri Feb 12, 2010 8:29 am
Will the iPad be capable of running the needed software to create iPhone apps?
PostPosted: Fri Feb 12, 2010 9:04 am
No ... the iPad does not have an Intel CPU.
PostPosted: Fri Feb 12, 2010 9:07 am
Thanks for the info. :)
PostPosted: Fri Feb 12, 2010 7:16 pm
thanks for the replys everyone,I found a mini over at frys for 400...I think I'll get this....and add more memory later
PostPosted: Fri Feb 12, 2010 7:30 pm
Be warned that Macs don't take regular memory, and Mac memory is expensive.
PostPosted: Fri Feb 12, 2010 8:20 pm
Million Club [PC]
Million Club [PC]
They technically don't, but on a Mac Mini, a DDR2 SO-DIMM will work the majority of the time. Getting the thing open is the hard part.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 5 guests
