It is currently Mon Mar 02, 2015 12:50 pm
 Post subject: Procedures in Java
PostPosted: Thu Aug 20, 2009 12:17 pm
I've tried googling it, I can't seem to find any relevant results.
How do I create procedures in Java? Basically I want to name a block of code and be able to call upon and execute that code when needed.
PostPosted: Thu Aug 20, 2009 12:37 pm
I can only think of creating a new object and placing the aforementioned code in that object. Then refer to the object you just created when you want to run that code. That's how I learned it anyway. Sorry if that's not really anything like want you want to do.
PostPosted: Thu Aug 20, 2009 8:34 pm
Million Club - 5 Plus*
You're looking for functions. Don't worry that they're all marked public static for now, as that will become more relevant when you learn more.
public class SimpleProgram {
    public static void Main(String[] args) {
        System.out.println("Hello from main");
        otherFunction();
    public static void otherFunction() {
        System.out.println("Hello from otherFunction()");
PostPosted: Fri Aug 21, 2009 7:40 am
OK, thanks that worked, but I have another question, is there a way of declaring a variable, and having that variable be able to be accessed anyplace in the program? Even if its in a different function?
PostPosted: Fri Aug 21, 2009 8:10 am
Super Mario Banhammer
Declare the variable as static inside a class:
public class GlobalDataStore
     public static long globalData = 0;
// you can now access this variable from other classes like so:
// GlobalDataStore.globalData  There will only be one value for globalData
// as it is declared static
PostPosted: Sat Aug 22, 2009 12:40 pm
If I do that, it says: This static variable declaration is invalid, because it is not final, but is enclosed in an inner class.
PostPosted: Sat Aug 22, 2009 9:54 pm
guoruiwu1994 wrote:
Declare the variable at the same level as the functions, inside of that same class instead of nesting the classes.
PostPosted: Wed Nov 11, 2009 1:34 am
Bitchin' Fast 3D Z8000*
Actually, otherFunction is a procedure, not a function. Functions return values, procudes work based on side-effects... come on, you're not old enough to be forgetting this stuff yet Smartcat! ;-)
This is the biggest problem using Java as a teaching language. =\
PostPosted: Mon Jan 18, 2010 7:03 pm
It looks like you're trying to use an object oriented language to write a non-object oriented program. There are a few instances where static functions and variables make sense, but their use should be more the exception than the rule. You may want to re-think how you're approaching the problem...or pick a language that's more suited to how you logically break down problems into algorithms.
PostPosted: Fri Jan 22, 2010 3:56 pm
I started in java and still have problems with oop. then again i can barely program. either way.
PostPosted: Mon Mar 01, 2010 11:36 pm
Dwood15 -- Java is actually a pretty damn good language in which to learn OOP. I would highly recommend that you spend some time with Bruce Eckel's Thinking in Java book -- he does a very good job of explaining the concepts w/o screwing things up with unnecessary crud (like using an applet to explain some OOP concept).
I listed it in the starting out thread or google it.
PostPosted: Mon Mar 01, 2010 11:45 pm
I disagree. There are plenty of instances where static methods are the correct choice. The use of static methods and static variables depends entirely on what you are doing. Would rewrite java.lang.Math? Making everything static is surely a sign of a bad design, but it sounds like you're tilting pretty far in the opposite direction which is also a mistake.
