It is currently Mon May 04, 2015 2:22 am
 Post subject: CPP scopes question
PostPosted: Mon Jan 18, 2010 9:21 am
I have a variable in global scope and need to access in a non-global scope, how do i do this?
 Post subject: Re: CPP scopes question
PostPosted: Mon Jan 18, 2010 9:53 am
Isn't that the whole point of Global variables?
PostPosted: Mon Jan 18, 2010 10:10 am
Here's the thing, I have an inline file called key_inputs
with the namespaces
Example { Key_Input{};};
My Variable(say, int examp) is in another file called example.cpp, if I try changing examp in a function inside of Key_Input, Visual studio tells me examp is an undeclared identifier.
PostPosted: Mon Jan 18, 2010 10:56 am
Nevermind, I found my answer here: http://www.learncpp.com/cpp-tutorial/42 ... variables/
Thanks for nothing my two stupid text books on c++ *twitch*
PostPosted: Mon Jan 18, 2010 10:58 am
Monkey Federation (Top 10)*
Your explanation of the situation is terrible, explain yourself better.
PostPosted: Mon Jan 18, 2010 11:00 am
Using a global variable across multiple files?
PostPosted: Mon Jan 18, 2010 11:03 am
The program could care less about the files as long as they are part of the program solution (read: #include) statements. Now you have twice explained yourself poorly.
PostPosted: Mon Jan 18, 2010 11:20 am
Don't be a dick.
That's my job.
:D
PostPosted: Mon Mar 01, 2010 11:23 pm
Bitchin' Fast 3D Z8000*
That isn't always an option. What if the global variable was in a shared library that didn't include the source code?
http://www.iu.hio.no/~mark/CTutorial/CT ... d%20extern
And yes, Dwood15 could have done a better job of explaining himself.
