It is currently Sun Mar 29, 2015 11:46 pm
 Post subject: help me with my html code
PostPosted: Fri Jan 08, 2010 4:42 pm
Hi im makeing a website and i cant figure it out i have the html code to go to my other page for the web site this
<a href="C:\Users\my name\Desktop\webpage\forum.html">forum</a>
that goes 2 my forum page and it works but when i do the samething back but with
<a href="C:\Users\my name\Desktop\forum\webpage.html">home</a>
Why dosent it let me go back to my home page? without hitting the back button :?:
PostPosted: Fri Jan 08, 2010 7:50 pm
Malware specialist
Malware specialist
You lost me here.
Why are you trying to put the homepage in the forum directory? Should your main homepage be under C:\users\username\Desktop\webpage instead of forum?
PostPosted: Fri Jan 08, 2010 7:52 pm
Million Club - 20 Plus
Why is this in the help me buy section? :?
Ted
PostPosted: Fri Jan 08, 2010 8:20 pm
i dont know ted.. i just wanted a quik answer and my website is saved up webpage i was makeing a link so i could go to my forum page and back to my home page the link to my forum page works but the link back to home doesnot i did the sam think for the link back to home but with the webpage and forum.html in a diffrent spot so it should send me back but its not working?.. anyhelp
PostPosted: Fri Jan 08, 2010 8:40 pm
Malware specialist
Malware specialist
Do you have a "forum" directory on your desktop?
If so, that doesn't really make sense since you are going back to the main page. Are you hand coding this web page or using something like Frontpage (or whatever they renamed it to)?
From the looks of your first line, it appears you have several different pages in a webpage directory.
What makes sense to me is:
<a href="C:\Users\my name\Desktop\webpage\webpage.html">home</a>
What files/folders do you have under that webpage directory?
PostPosted: Fri Jan 08, 2010 9:01 pm
Im hand writeing it in notepad and what im trying to do say i go to this forum section on this website and i want to go back to the home page of this website i click home and it should take me where but mine wont and i have a forum file yes if thats what you mean.
PostPosted: Fri Jan 08, 2010 9:03 pm
HEY! the one you posted worked! it dident make sence to me tho so you go to webpage by searching and loading webpage? that what it looked like to me hmm o well it worked thx!
PostPosted: Fri Jan 08, 2010 9:31 pm
Malware specialist
Malware specialist
It works because your webpage.html page is in the webpage directory, not in a directory called forum.
When you press the button (or go to a webpage), it looks through all the folders. For your example, it looks through your C drive, then user account folder, then Desktop and then for a folder named forum, which probably doesn't exist. Since it doesn't exist, the .html page cannot be found and won't work. A directory and file is a total different thing remember (directory = folder).
Make sense?
PostPosted: Fri Jan 08, 2010 10:24 pm
O ok thanks for the help still learning how to make a website thx!
