It is currently Tue Jan 27, 2015 12:50 am
 Post subject: Peer Guardian alternative ??
PostPosted: Mon Dec 14, 2009 9:44 am
I have windows 7 and peer duardian doesnt work on it, is there any alternatives ??
PostPosted: Mon Dec 14, 2009 10:27 am
Peer Guardian does work on Windows 7: Link to manufacturer
PostPosted: Mon Dec 14, 2009 4:21 pm
after i install it i get an error message with driver signature ??
PostPosted: Mon Dec 14, 2009 4:29 pm
It's because you are on 64bit, and Peer Guardian is 32bit only. This is a workaround:
Disable UAC > reboot > download DSEO 1.2 (should be the first link on Google) > patch C:\Program Files\PeerGuardian2\pgfilter.sys with the tool and set the system to test mode, with the tool > then reboot.
PostPosted: Tue Dec 22, 2009 11:33 am
PeerBlock.
PeerGuardian will randomly crash under extreme loads on my old, crappy system.
PostPosted: Wed Dec 23, 2009 1:03 pm
Team Member Top 250
Team Member Top 250
To add to the above post, here is a link to PeerBlock. Its build from the Peer Gaurdian source code and made for different versions of Windows including 32 and 64 bit versions of Vista and 7 which PG didn't support.
PostPosted: Thu Dec 31, 2009 3:27 pm
I personally use PeerBlock and have no complaints. No more crashes and seems to work as good as original PG2, if not better.
