It is currently Thu Jan 29, 2015 9:37 pm
 Post subject: Questions on HAF 932 mod
PostPosted: Thu Dec 17, 2009 10:11 pm
Hey, I am working on my first mod and I have a HAF 932 case to work with. My current issue is that I purchased a dual 5.25 bay water cooling resevoir for my case and would like to install it in the front of the case, but the platforms that are for holding the 5.25 devices are preventing it from sliding in. How do I go about removing these?
PostPosted: Thu Dec 17, 2009 10:29 pm
did u push the buttons for the mounts so that the pins are not sticking into the case? if they are in the unlocked position, it should be smooth sailing.
PostPosted: Thu Dec 17, 2009 10:37 pm
I have done that, its the metal platforms that the devices sit on, if you know what I mean.
PostPosted: Fri Dec 18, 2009 12:24 am
oh those. any way u can avoid filing them down or folding them up? if u have to reorganize the front later on, might be kind of difficult to hold devices in the bays if there's no bottom tabs to support them.
PostPosted: Fri Dec 18, 2009 12:27 am
No, the reservoir wont fit unless i do.
