It is currently Sun Jan 25, 2015 6:32 pm
 Post subject: some noob questions
PostPosted: Wed Dec 16, 2009 4:27 pm
Million Club 5+ [PC]*
recently my main desktop died, and I have been forced to you my linux laptop as my main computer. so this is the first time I have used linux extensively
as for my first question, is there a keyboard command in Ubuntu similar to Ctrl-shift-esc (and ctrl-atl-delete) where you can bring up a task manager type program. I have been at a loss what to do when my computer locks up so I have been forced to restart.
for my second question, is there an in depth hardware info program similar to CPUZ that I can use?
 Post subject: Re: some noob questions
PostPosted: Wed Dec 16, 2009 8:48 pm
Gnome System monitor You could probably program the key sequence you're talking about via the keyboard shortcuts applet (another Gnome tool)
Not sure what to tell you here as I'm uncertain if you can find all you need in one package. I know gnome panels has a CPU frequency scaling monitor you can add (right click somewhere on your task bar and select add), but it sounds like you want more.
I'd think somewhere like gnome-look.org would have a decent desklet to use for that. If not there, gnomefiles.org would probably have something.
PostPosted: Wed Dec 16, 2009 10:31 pm
hmm I tried exec gnome-system-monitor. and while that worked in the terminal it failed when I tried binding it to a keyboard shortcut.
do you have any suggestions?
PostPosted: Thu Dec 17, 2009 7:17 am
I just run the plain binary without exec
Perhaps the esc key may be causing some issue here.
PostPosted: Thu Dec 17, 2009 1:54 pm
thanks, that worked. I took off exec and it worked fine. for some reason I thought I needed a command first
now I only need to see if this will work when my system locks up
PostPosted: Sat Mar 13, 2010 5:39 am
Gailim, try to use the "ctrl" + "esc" keyboard combo when it locks up, that usually unfreezes a system lockup, and it works in Linux, Mac, and Windows. (note: the Apple logo key replaces the "ctrl" key in a Mac.)
PostPosted: Sat Mar 13, 2010 7:39 am
dude...try not to drum up old theads...this thing is close to 3 months old.
