It is currently Sun Apr 26, 2015 4:35 pm
 Post subject: updating SSL via SSH login to server
PostPosted: Thu Dec 10, 2009 11:49 am
Team Member Top 250
Team Member Top 250
I'm still a noob to Apache and i'm trying to update the SSH on our webserver to disable SSLv2 and only use SSLv3.
So i connect to the root user via putty
type OpenSSL: SSLProtocal -All +SSLv3 +TLSv1
and....
-bash: OpenSSL:: command not found
What am i doing wrong?
PostPosted: Fri Dec 11, 2009 10:16 am
Monkey Federation (Top 10)*
openssl is case sensitive first of all and second the command may not be in your path depending on the method used to acquire the root login.
I would login as root and run
locate openssl | more
to find the location of the binary. Then adjust your command to include the full path to openssl.
On my server it is located in /usr/bin/openssl
PostPosted: Fri Dec 11, 2009 10:18 am
And please edit the subject line, and the first line of the OP, to correctly reflect what we are talking about here. SSH is a secure shell environment where SSL is Secure Sockets Layer; the two are not even remotely related.
PostPosted: Fri Dec 11, 2009 10:20 am
Team Member Top 250
Team Member Top 250
[root@.......]# locate openSSL | more
-bash: locate: command not found
PostPosted: Fri Dec 11, 2009 11:58 am
Million Club - 5 Plus*
I think that you're looking to edit the apache configuration file instead of using openssl.
In my /etc/httpd/conf/httpd.conf I have these lines:
SSLProtocol +all -SSLv2
SSLCipherSuite HIGH:MEDIUM
PostPosted: Wed Dec 16, 2009 12:23 pm
Team Member Top 250
Team Member Top 250
Thanks, we ultimatly went with a shared host who is already PCI complaint then try and master Apache.
