It is currently Sat Jan 31, 2015 8:36 pm
 Post subject: USB drive harddrive
PostPosted: Fri Dec 11, 2009 8:13 am
Due to kids or wife my harddrive upped and died from smart drive failure. Until I can purchase a new harddrive (after christmas) I am using Xubuntu from my jump drive. It is being used as a harddrive, but how can I get it to run faster. I have 2G of ram, but it is not being used. How can I use the 2G ram to my advantage?
PostPosted: Fri Dec 11, 2009 8:23 am
IMO
Boot a Live CD and use the USB to save any files you need to save.
PostPosted: Fri Dec 11, 2009 10:11 am
Monkey Federation (Top 10)*
CrashTECH wrote:
IMO
This.
The live cd boot is slow as shit but once running you will take advantage of the 2GB system ram as a ramdrive and all programs/processes will run straight from memory. With the USB system you are using I don't think that everything is run from memory so you have the lag of reading and writing system information across the USB controller.
PostPosted: Fri Dec 11, 2009 4:38 pm
Heck...if you went as far as using the USB stick, why not just install on the USB HD?
At least then you can get around the clunkiness of the LiveCD.
PostPosted: Fri Dec 11, 2009 7:08 pm
I am on a tight budget until after christmas. I only have an 8 gig usb stick. I needed to have installed permanent w32codecs as well have my email permanent. I have limited time on the computer.
