It is currently Wed May 06, 2015 3:48 am
Post new topic Reply to topic  [ 59 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Nov 27, 2009 6:29 pm
It has been working for you then?
I still want to give it a few updates, because it does need it. Does it start and stop F@H properly?
PostPosted: Fri Nov 27, 2009 7:07 pm
Malware specialist
Malware specialist
It seems to (I still need to test it on my main computer, at home right now), but when I launched some files with notepad with the same name it worked properly.
I did have to make one modification to the code because you can't start the individual core files, you have to start the actual client after it's been closed (ie. Folding@HomeGPU.exe).
I will give an official test report when I go home on Sunday.
PostPosted: Sun Nov 29, 2009 3:26 pm
Malware specialist
Malware specialist
All right, I just tried it with my desktop computer and it did not work.
There were no errors or anything, it just didn't do anything.
ehrec launched, but the clients kept on folding.
PostPosted: Sun Nov 29, 2009 6:17 pm
Yeah, we have to change the user account it runs under. I set it up to install to run under a different user account.
If you change it to run as the "user" and it should work.
PostPosted: Sun Nov 29, 2009 6:35 pm
Malware specialist
Malware specialist
What do you mean by change it to run as the user?
I was able to make it run as a Network Service (through services.msc, which is how I have it set up at the moment)
PostPosted: Sun Nov 29, 2009 6:41 pm
In the install project, you can set it up to install it under a specific user account. Network system, local system, etc. They probably won't work. You'll need the user account.
I don't remember off the top of my head where it is you need to change it at. That should fix it. I won't be able to get to it tonight but I can probably check it out tomorrow and get back to you.
What did you have to change about it?
PostPosted: Mon Nov 30, 2009 7:07 pm
Malware specialist
Malware specialist
I couldn't find anywhere in VS to change the installation under a specific account.
The install wizard gives an option of "Everyone" or "Just Me". I have tried both with no success.
I can change the service owner through services.msc, but I'm not sure how much that helps.
PostPosted: Mon Nov 30, 2009 10:13 pm
Million Club - 5 Plus*
Editing the user through services.msc is just as good as setting it in VS.
PostPosted: Tue Dec 01, 2009 4:23 am
I guess, I didn't see where I could set it to run as the logged on user. It will let you specify a specific user... but that wasn't what I was looking for. If somebody else logged onto the machine the service wouldn't work.
I should have time today to tweak it.
Hack, can you upload a zip of the project? I'd like to take a peek at what you changed? I can modify my version and change the installer.
The problem I saw was that it would start calc.exe (in my testing) but it would be running as the system user and I would not ever see the calc window.
PostPosted: Tue Dec 01, 2009 1:35 pm
Malware specialist
Malware specialist
Here is what I changed: http://rapidshare.com/files/314952629/S ... atcher.zip
I'm not sure if it works (I tweaked ServiceWatcher.cs) because I can't get it to see the client.
PostPosted: Tue Dec 01, 2009 5:10 pm
Services are not allowed to interact with the desktop without the allow service to interact with desktop flag set. (on the same page as the select an account in services.msc)
I think they were trying to get rid of that in Vista/7+ as well.
PostPosted: Tue Dec 01, 2009 6:35 pm
The installer takes care of that. The problem I had was it was running calc under the system account. The process started but was not visible to the user.
PostPosted: Wed Dec 02, 2009 5:35 am
Ugh... RS is blocked at work. I should have downloaded it last night. Figures.
There is no client window or anything to speak of. To debug you install the service and then attach visual studio to that process.
PostPosted: Wed Dec 02, 2009 5:56 am
Malware specialist
Malware specialist
Here are some more download links, any of these work?
http://www.multiupload.com/AV6V8G9SCS
PostPosted: Wed Dec 02, 2009 6:57 am
media fire worked.
PostPosted: Fri Dec 04, 2009 6:48 am
Malware specialist
Malware specialist
Just in case this ends up not working (which it probably will work, but this is just an option).
I made the following. It doesn't work (because I don't know much about Windows Powershell).
$Process = Get-Process | Where-Object {$_.ProcessName -eq "ehrec.exe"}
If (!($Process))
    "Process is running"
    invoke-item C:\Users\hackman2007\Desktop\Suspend.bat
Else
    invoke-item C:\Users\hackman2007\Desktop\Resume.bat
Only problems with the above are:
1. It doesn't do the else part and I'm not sure how to fix it.
2. I'm not sure it's good form to keep resuming the same process, but it shouldn't do anything. Not sure if there is a way to tell if something is idle in Windows Powershell.
Anyways, just another option if the program turns out too much work or doesn't work as intended.
PostPosted: Fri Dec 04, 2009 6:50 am
Sorry, been busy at work... year end reviews... have to finish up my "workbook" about what I did this year..
/sigh
PostPosted: Fri Dec 04, 2009 9:18 am
Malware specialist
Malware specialist
/sigh
I'm not in any hurry. I was just presenting an alternate way to possibly accomplish the task in case the program becomes too time consuming to continue.
But anyways, good luck on the year end reviews, always nice going back to "document" what you did ;) .
PostPosted: Fri Dec 04, 2009 10:00 am
I tired to keep up with it through the year, and only partially succeeded.
