It is currently Thu Feb 26, 2015 3:48 pm
 Post subject: Rj-46 to usb
PostPosted: Wed Nov 18, 2009 9:37 pm
Is it true that u could cut the usb cable and connect it to the rj 45 cable?
PostPosted: Wed Nov 18, 2009 9:43 pm
Million Club [PC]
Million Club [PC]
no. RJ45 is electrically incompatible with USB, and they're for different applications. RJ-11 does have the same pin count as USB, but it's still electrically incompatible. You could cut the USB connectors off a USB cable and splice in RJ11 connectors on both sides, but that just makes it a janky RJ11 cable.
PostPosted: Thu Nov 19, 2009 7:38 am
I have seen a build where a guy used a eithernet switch for a itx build and made custom rj45-usb cables and then used the eithernet ports for usb ports.
so i would say it is possible.
PostPosted: Thu Nov 19, 2009 7:48 am
Million Club [PC]
Million Club [PC]
As far as I know, the only USB-RJ-45 is USB ethernet, which requires an active adapter.
PostPosted: Thu Nov 19, 2009 9:24 pm
do you remeber when you seen this?
PostPosted: Fri Nov 20, 2009 12:02 am
Im pretty sure it was over at www.xtreamsystems.org.
PostPosted: Sun Nov 22, 2009 2:59 pm
Team Member [Top 500]*
We need a little clarification here before anything else.
The RJ45 is a connector type and not a cable. A RJ45 connector has 8 positions and is commonly used for LAN applications using a CAT 5 or CAT 6 cable. The actual pin out can be configured for a patch cable or for example a crossover cable in LAN apps. Of the 8 lines only 4 are actually used in LAN applications. There are 4 data lines and no power lines within the LAN configuration.
This is a good read on that note. Just remember there is no RJ45 cable. RJ45 is a connector type.
USB is just that it is a Universal Serial Bus and only has 4 lines used. However those 4 lines include power of 5 Volts and a common and only 2 data lines. In this case the connector used is called a USB connector.
Any connector can be used in a custom application depending on if the connector will do the job required of it.
This link explains many of the LAN protocols in use.
This link explains USB protocol.
The key word there is custom. Yes, that can be done.
Ron
