It is currently Thu Mar 26, 2015 7:03 pm
Post new topic Reply to topic  [ 66 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Cooler Master 840 Project
PostPosted: Wed Oct 28, 2009 4:00 am
Hey gang, I've started the build for Cooler Master's media suite at 2010 CES. The D-9 concept was mine after seeing the movie.
I should know by first week of November what hardware CM will be sending me.
Conceptual drawing by E.E.L. Ambiense
The canvas for this PC build is the Cooler Master 840 ATCS
Adding window to Cooler master 840 ATCS
Using tape roll to make curved corner
Make first initial cut with your Dremel and cutting wheel, to allow use of Jigsaw and cut the window more efficiently
You have created slot, this allows using a Jigsaw w/ 18 TPI cutting blade
Using a Jigsaw is much quicker than using a Dremel to cut your window
Use a rounded side file to debur the jagged edges of the new window
Notice the window location doesn't reveal the drive bays, this was intentional.
PostPosted: Wed Oct 28, 2009 10:20 am
Million Club [PC]
Million Club [PC]
looks very nice. Thanks for providing a worklog too, I don't think the mods will have a problem with this one. :wink:
dremel+jigsaw=surprisingly easy window cutting. Nothing else works nearly as well.
PostPosted: Wed Oct 28, 2009 10:56 am
How much does a jigsaw+dremel cost? I want to get into modding, but i hate borrowing my neighbor's tools.
PostPosted: Wed Oct 28, 2009 8:31 pm
Dremel @ 69.99 @ Home depot
Jigsaw @ $40 @ Home depot
Upgrading the 840's stock 120mm exhaust fan to 140mm fan.
Cooler Master 840 ATCS rear 120mm exhaust
I'm holding up a 140mm Cooler Master fan over the stock 120mm grill. "Will it fit without anything obstructing it?"
The location of the 140mm fan resides along the crease on the back plate.
Making the initial cut with Rotary tool and reinforced cutting wheel before using Jigsaw
Using Jigsaw with 18 TPI metal cutting blade
Using rounded side hand file to clean up burrs along the edge of the cut.
140mm opening is cleaned up, next is drilling mounting holes for 140mm fan
vibration dampening fan grommets
Using a 1/4" size drill bit to make the mounting holes, this allows the fan grommets to fit.
Vibration dampening fan grommets installed.
PostPosted: Wed Oct 28, 2009 8:50 pm
Million Club [PC]
Million Club [PC]
wow, so you just took a straight shot with that jigsaw to cut a round hole? That takes skilz beyond mine. As for the dremel, I'm still rolling with an original- they were more then $70 back then. :wink:
PostPosted: Thu Oct 29, 2009 12:07 am
Nice to see you made to to Maxpc i have been following this on XS for some time now.
PostPosted: Thu Oct 29, 2009 2:59 am
Cool! Thanks for the comments!
PostPosted: Thu Oct 29, 2009 4:01 am
I like the improved "how to" photos. This is good! Exactly what we like to see! Looking forward to seeing the results!
If you are serious about modding, I recommend this kit:
http://tinyurl.com/Dremel-MultiPro-77-Acces-kit
PostPosted: Thu Oct 29, 2009 9:40 am
Thats cool! Thank you for the feedback and suggestions. I really like the F-150 pick-up from District 9
For the exhaust fan grill, I cannibalized an early Monsta Rad grill prototype we made this year.
PostPosted: Fri Oct 30, 2009 6:06 am
We've cnc milled the "District 9" design in the Cooler Master 840 aluminum intake plate. The recessed center portion will be the CM case badge
PostPosted: Fri Oct 30, 2009 6:49 am
Lookin' sweet so far!
PostPosted: Sat Oct 31, 2009 6:14 am
Team Creamsicles
Team Creamsicles
How much is that mill machime, and give it to me!
:lol: :lol: :lol:
PostPosted: Sat Oct 31, 2009 7:16 am
Million Club [PC]
Million Club [PC]
CNC's are damn expensive, but you can order anything to be CNC'ed from a local machine shop. I know for sure that the vast majority of them will take an autoCAD file and dimensions (and money of course) and send you back the finished product.
PostPosted: Thu Nov 05, 2009 9:27 am
We lease our HAAS 5 axis, you can pick up a used one for $120,000
I've cut the window from Lexan. It's tougher than plexiglass/acrylic, but 2 or 3 times more expensive. It won't shatter or crack "easily" You can buy Lexan sheets at Home Depot, Lowes and some hardware stores like Ace.
The window will be fastened with 1/4" socket head screws, for reinforced armour look
Using center punch to mark each fastener hole.
Roper Whitney No. 5 Jr Hand Punch kit available here
Hand punch (estimate $60 new)
"Look Ma, No deburring needed!"
The benefit of using Lexan is that you can drill or hand punch it without cracking it.
Clean hole cut! I love Lexan.
Ironically our concept drawing calls for bullet holes in the Lexan "bullet proof" window...lol
PostPosted: Thu Nov 19, 2009 6:01 am
Cooler Master's hardware list for their CES show display
1 x Intel Core 2 Duo E8500 Wolfdale 3.16GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor
1 x Intel Extreme Series DX48BT2 X48 Motherboard
1 x Silent Pro RS-600-AMBA-D3
1 x CM MITX Cooler 38mm tall (will be replaced with future V series cooler)
1 x Sapphire ATI Radeon 4870 512MB
1 x 4GB DDR3 Kingston 1600mhz memory kit
1 x WD 500GB HDD
1 x DVD drive
Silent Pro RS-600 Watt-AMBA-D3 PSU
http://www.newegg.com/Product/Product.a ... 6817171036
Are you a fan of the Black Ribbon power cables?
PostPosted: Thu Nov 19, 2009 6:05 am
Million Club [PC]
Million Club [PC]
wow that's kind of a craptastic hardware list for such a nice case. :?
the mod looks great though. As for your question, nylon-mesh sleeved cables are so much better.
PostPosted: Thu Nov 19, 2009 10:46 am
The concept called for bullet holes in the window
Using 3/8" drill bit
Using wire cutter to make cracks around the hole
Etching Rotary Tool (or Dremel) Engraving Bits
Using the dremel to emulate some cracks
PostPosted: Thu Nov 19, 2009 11:44 am
Million Club [PC]
Million Club [PC]
you should have just taken the side panel to a shooting range. :wink:
PostPosted: Thu Nov 19, 2009 12:04 pm
I thought he said they were using Lexan, which is bullet proof...
PostPosted: Thu Nov 19, 2009 2:01 pm
Million Club [PC]
Million Club [PC]
no, lexan is not bullet proof. lulz. I've used it before- it's sturdier then plexiglass, but certainly NOT bullet proof. He said that the theming was to make it look like a bullet proof window.
