It is currently Sun Apr 19, 2015 12:30 am
 Post subject: Function Keys
PostPosted: Sun Nov 15, 2009 7:35 pm
Hey guys,
HOW do you RE-MAP function key such as <F1> to be <PAGE UP> ?
Basically I always need to <ctrl><alt><f1> then <ctrl><alt><f7> whenever my mouse dissapears (typical compiz bug); but Function keys doesn't work anymore in the linux that I'm using.
Thanks for the help !
PostPosted: Mon Nov 16, 2009 8:00 am
xmodmap I don't remember this as being a real simple tool though
maybe someone has a simpler solution...
PostPosted: Mon Nov 16, 2009 1:25 pm
For Gnome desktops: System ----> Prefrences ----> Keyboard Shortcuts
For KDE desktops: run kcmshell keys
PostPosted: Mon Nov 16, 2009 3:15 pm
Hi thanks guys :)
I use KDE by the way and I can't find the KCMSHELL command. Do I need to download it ?
PostPosted: Mon Nov 16, 2009 3:23 pm
Which distro are you running? I'm fairly certain it's already installed.
I believe Alan gave info specific to whatever he's running..as Keyboard Shortcuts for me is under system -> configuration.
PostPosted: Mon Nov 16, 2009 6:40 pm
logicmaster2003 wrote:
Hi thanks guys :)
You type it at a shell to invoke the KDE control module. From what I've read, its not listed in the control panel so you have to do it that way.
PostPosted: Thu Nov 19, 2009 10:06 pm
hi guys :)
Thanks for the help :) but i still can't find kcmshell anywhere. I'm using mandriva2010.x by the way.
What I've done is move my usb KVM switch to another usb port and the function keys came back ! Then i moved the KVM switch back to the original usb port and its working still :)
weird huh ?
and i almost was gonna ditch my kvm switch and just plug a regular ps2 style keyboard
