Watch the "I'm Staypuff and I Fold" video
Vote for November's PSOTM
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups    Ban PanelBan Panel   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
First build, gaming/multimedia/school PC
Post new topic   Reply to topic     Forum Index -> Help Me Buy/Help Me Build
View previous topic :: View next topic
Faulkner16
PostPosted: Fri Nov 06, 2009 8:48 pm    Post subject: First build, gaming/multimedia/school PC Reply with quote
Hi, this will be my first build and i admit im a bit nervous as to how it will all play out. Basically im looking for a moderate gaming PC, and i will also be streaming movies, and using programs like photoshop, office, illustrator, synergy, as well as some DVD burning. So basically heres what im looking at so far:
MOTHERBOARD
- Asus P7P55D EVO - LGA 1156
http://www.tigerdirect.ca/applications/searchtools/item-Details.asp?EdpNo=5083578&sku=A455-2912&srkey=Asus%20P7P55D%20EVO
CPU
- Intel Core i7 860, 2.80 Ghz - LGA 1156
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=4959972&csid=ITD&body=MAIN#detailspecs
RAM
- (2) Corsair Dominator DHX 4GB DDR3, dual channel, 1600mHz
http://www.tigerdirect.ca/applications/searchtools/item-details.asp?EdpNo=4837612&csid=ITD&body=MAIN#detailspecs
Video Card
- XFX Radeon HD 5770 - 1Gb DDR5
http://www.tigerdirect.ca/applications/searchtools/item-Details.asp?EdpNo=5316156&sku=P450-5770&srkey=xfx%20radeon%20hd%205770
CASE
- NZXT Tempest
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=3911521&CatId=1842
PSU
- Corsair TX750W - 140 mm fan
http://www.tigerdirect.ca/applications/searchtools/item-details.asp?EdpNo=3438609&pagenumber=1&RSort=1&csid=ITD&recordsPerPage=5&body=#ReviewStart
HARD DRIVE
- Seagate Barracuda 1 TB 7200 rpm, 32mb, SATA3G
http://www.tigerdirect.ca/applications/searchtools/item-Details.asp?EdpNo=4691122&sku=TSD-1000AS3&srkey=seagate%20st31000528as
OPTICAL DRIVE
- SAMSUNG SH-S223C
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=5344784&CatId=1624
OTHERS
thermal grease?
hard drive SATA cables? mounting screws? (hard drive is OEM)
so my budget is 1500 right now, and i shouldnt need to have any of these parts shipped (near many computer parts stores). Right now this build is at about 1300. However, i will be getting a netbook/small laptop as well with a total budget of 2000.
Here are my questions/concerns:
1- Ive been reading up on the i7 860 vs the i7 920, and since i will most likely not be overclocking (maybe down the road) the 860 has similar, if not better benchmarks than the 920, so i decided to go with it. I still have the 920 in the back of my mind though.
2- should i save money and go with 1 set of the memory? will 4GB be enough/sufficient?
3- I have also been reading on the radeon 5770 vs the 4890, and opted for the 5770 because of the future directx11 support and lower running temp and power. However, there is also a bit more room in my budget for something more powerful. I wont be doing real hardcore gaming, but would like to see some good framerates when i do.
4- 750w should be enough right?
5- What will i need to assemble this project. ie what will not be included in the parts when i get them.
- things like thermal grease(or will the CPU already have it) mounting screws, cables)
- as well as tools. should i buy a specialized kit with an antistatic bracelet, even though i dont plan on doing future builds for a while? or will normal screwdrivers etc be enough.
Thanks for any input!
Very Happy[/url]
Back to top
View user's profile Send private message
Gailim
Million Club 2+ [PC]
PostPosted: Fri Nov 06, 2009 8:57 pm    Post subject: Reply with quote
first, please link the the parts you are considering
now for your questions
1. stick with the 860 (though I think the 750 would be better). the 920 requires a more expensive mobo
2. 4GB (2GBx2GB) is enough for just about anything today. if you need more later than buy more later. buying lots of ram now makes little sense because by the time you need that ram it will be much cheaper
3. I think you could probably swing a 5850 by tweaking the rest of your build (more on that in a sec)
4. extreme overkill
5. if you intend to use the stock cooler, it already comes with paste pre-applied. if you want to use an aftermarket heatsink then you will need your own paste. one phillps head screwdriver is all you really need. you can get the bracelet if your paranoid, but I have never needed it. just don't build on carpet and ground yourself before starting
if you link to the parts you are considering I can tweak your build to save money in various places for little to no performance loss. then you might be able to get that 5850. which reminds me, you never said what resolution you were playing at. could you fill us in? that has a big impact on what card is best for you.
Back to top
View user's profile Send private message Visit poster's website
Faulkner16
PostPosted: Fri Nov 06, 2009 9:09 pm    Post subject: Reply with quote
thanks for the reply,
would you say 500 or 600 watt psu instead?
- good point about the ram, and i think thats what i will do, although i do have one question:
is ram interchangeable? if i were to stick with the 4gb now, then opt for more late,r would i have to get the same ram, or could i get a different brand/model?
also, does the 5850 boast a significant increase in performance over the 5770?
Back to top
Gailim
PostPosted: Fri Nov 06, 2009 9:14 pm    Post subject: Reply with quote
depends on what GPU you decide on. for a 5770 you can go with a quality 400W unit. for the 5850 a quality 500W unit will do
Faulkner16 wrote:
- good point about the ram, and i think that's what i will do, although i do have one question:
no you can use any DDR3, though it would be best to get the same speed/latency.
hoo boy does it ever Laughing
but once again, that depends on whether you need that kind of power. what resolution do you play at?
Back to top
Faulkner16
PostPosted: Fri Nov 06, 2009 9:20 pm    Post subject: Reply with quote
well that could vary, 1280 x 1024 as of right now, but im considering getting an lcd with the new system with a 1920 x 1080 display
Back to top
Gailim
PostPosted: Fri Nov 06, 2009 9:29 pm    Post subject: Reply with quote
ok after looking at your parts we can shave tons off that build (some of that has to do with your part selections, some with the fact that TD is overpriced)
as for your resolution, at 1280x1024 even a 5770 would be overkill. I'm gonna go ahead and list a monitor as well since I was able to save so much
also, 5850's are hard to come by in stock but it is worth it to wait
here is what I would do
XFX HD-585A-ZNFC Radeon HD 5850 (Cypress Pro) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card $300
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150442
SeaSonic SS-500ET Bronze 500W ATX12V v2.31 80 PLUS BRONZE Certified Active PFC Power Supply $70
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151080
ASUS VH222H Black 21.5" 5ms HDMI Widescreen 16:9 Full HD 1080P LCD Monitor Built in Speakers $160 ($150 after MIR)
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236053
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case $70
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
ASUS P7P55D LE LGA 1156 Intel P55 ATX Intel Motherboard $130
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131410
Intel Core i5-750 Lynnfield 2.66GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor $200
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
OCZ Obsidian 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory $79 ($59 after MIR)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227495
Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive $90
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148433
LG Black 22X DVD+R 8X DVD+RW 22X DVD-R 16X DVD-ROM 48X CD-ROM 2MB Cache SATA DVD Burner $29
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136167
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders $107
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
TOTAL = $1,234.90 - Rebates + S&H
questions? comments? what do you think?
Back to top
Faulkner16
PostPosted: Fri Nov 06, 2009 9:39 pm    Post subject: Reply with quote
Wow! thanks so much for the effort, ill definitlely be checking these out!
Back to top
guoruiwu1994
PostPosted: Sat Nov 07, 2009 7:06 am    Post subject: Reply with quote
The links that Gailim posted are from newegg.com, the ones that Faulkner posted are from tigerdirect.ca
Back to top
Faulkner16
PostPosted: Sat Nov 07, 2009 7:36 am    Post subject: Reply with quote
yes, i will have to find a canadian alternative to these but that shouldnt be too hard. newegg.ca usually has a price increase compared to the american site, but thats not much of an issue
Back to top
iPood
PostPosted: Sat Nov 07, 2009 8:54 am    Post subject: Reply with quote
NCIX.com has some good monitors at a good price. (Its a Canadian site)
Acer X223H 23" $179
http://www.ncix.com/products/index.php?sku=35696&vpn=ET.VX3HP.002&manufacture=Acer&promoid=1120
Back to top
Display posts from previous:
Post new topic   Reply to topic     Forum Index -> Help Me Buy/Help Me Build All times are GMT - 8 Hours
Page 1 of 1
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
Future © 2008 Future US, Inc. All Rights Reserved.
