Watch the "I'm Staypuff and I Fold" video
Vote for November's PSOTM
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups    Ban PanelBan Panel   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
First time builder, How will this do?
Post new topic   Reply to topic     Forum Index -> Help Me Buy/Help Me Build
View previous topic :: View next topic
ttotsbarc
PostPosted: Tue Nov 03, 2009 7:10 pm    Post subject: First time builder, How will this do? Reply with quote
I've been on here the last 2 months or so and at one point I was going to buy a computer but things didn't pan out with my budget. I've worked out my budget so I will be buying parts this upcoming holiday (I'm planning on buying it the weekend of Thanksgiving because there are supposed to be GREAT deals then)
I'm planning on building a computer for the first time. I will be using some pre-existing parts from my current computer and I will buy some new parts.
I plan to use this computer primarily for Photoshop CS2, Maya 2008 and to play "high end" fps games (arma II, Crysis, COD, FarCry2 etc.)
Here is a list of what I currently have and will be re-using and then a list of new parts.
Re-use:
-ViewSonic A91f+ at 1280x1024 (max 1792 x 1344).
http://www.newegg.com/Product/Product.aspx?Item=N82E16824116048
-Cooler Master Centurion 5 CAC-T05 case.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119077
-PC Power and Cooling 610 Watt (80 plus) sli certified power supply
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3247723&CatId=1483
-2 DVD drives
-Keyboard, mouse, and speakers.
New Parts to buy:
-Intel i-5 ($200)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
-GIGABYTE micro ATX ($110)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128405
-XFX 4890 ($200)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150438
-Win7 OEM ($107)
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
-G Skill 4GB ($90)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231193
-500GB hard drive ???
After asking TONS of quesions on this forum and searching around a bit, this is what I think will be best for me. By the way, my budget is $700 or less.
I know, Im allready at $700 without the Hard drive included but I figured that I can buy these in bundles and buy them durring the Thanksgiving holiday to drop the price quite a bit... I hope Smile
Please let me know what you all think, and what I should change. or if there is a cheaper route to go.
And THANKS AGAIN for all of your patience and time!!!
Back to top
View user's profile Send private message
Spartacus
PostPosted: Tue Nov 03, 2009 7:13 pm    Post subject: Reply with quote
You can save some money by swapping out that 4890 for a 5770. Though it's performance is lesser then the 4890's, a 4890 is rather overkill for 1280x1024 (I'm running my 4870 1GB on a 1280x1024 panel pending a monitor upgrade and can entirely max out every game I own except for STALKER, Crysis, and Far Cry 2 without it breaking a sweat), and it supports DX11 and is $40 cheaper. That lets you get an HDD now without going much over budget.
Back to top
ttotsbarc
PostPosted: Tue Nov 03, 2009 7:36 pm    Post subject: Reply with quote
ya, i thought about getting the 5770 but im planning on getting a 23' or 24' HD monitor soon in the near future...I'm down with getting the 5770 unless you think that the 4890 would be a better bet for the long run.
Smile
Back to top
ttotsbarc
PostPosted: Tue Nov 03, 2009 8:12 pm    Post subject: Reply with quote
i was looking around and I think I'll go with this Hard Drive:
Samsung 500GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181
and maybe to save a few bucks I could go with this RAM:
OCZ 4GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227495
Back to top
Spartacus
PostPosted: Tue Nov 03, 2009 8:14 pm    Post subject: Reply with quote
Smile
since the 5770 is a brand-new platform, adding another a few months down the road is a viable option. So you could just stick with a 5770 and then add one whenever you upgrade the monitor.
Back to top
ttotsbarc
PostPosted: Tue Nov 03, 2009 8:20 pm    Post subject: Reply with quote
would it be worth the extra $40 to get the 4890 now rather than buy another 5770 in the near future since that'll cost me more than $40?
(i hope that makes sense)
are the 4890 and 5770 really that much different in performance? and will the directx 11 be much of an advantage?
I guess I would rather avoid getting 2 video cards if possible(less maintinance and it's cheaper).
Back to top
Spartacus
PostPosted: Tue Nov 03, 2009 8:32 pm    Post subject: Reply with quote
the 4890 is about 20% faster, pretty much dead-on with the price difference. It's just another option to spread out the costs over time.
Back to top
Danthrax66
PostPosted: Tue Nov 03, 2009 9:56 pm    Post subject: Reply with quote
what graphics card do you have now?
Back to top
iPood
PostPosted: Tue Nov 03, 2009 10:04 pm    Post subject: Reply with quote
The 5770 actually performs a little worse then the 4870 (due to the neutered 128bit memory bandwidth on the 5770 vs the 256bit on the 4870/4890, all 3 cards have 800 shaders) . If you are going to be upgrading to a 23/24" monitor (most have a resolution of 1920x1080/1200) than the 4890 is the way to go. True you don't get dx11 but by the time dx11 games become standard the 5770 may not be able to perform adequately at 23/24" resolutions (Heck it isn't even ideal right now for 1920x1080/1200 resolutions). Furthermore, the gigabyte mobo you picked is awesome but not ideal if you want to go with a 2nd card down the road as its 2nd pcie slot operates at 4x. Get that mobo if you aren't planning on crossfire.
Here is another suggestion on the hard drive but the samsung you picked out is good as well. The 1TB seagate 7200.12 was rated pretty high with maxpc magazine. the 500gb samsung you picked out is rated quite high with tomshardware.
Seagate 7200.12 500gb
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148395
Back to top
ttotsbarc
PostPosted: Wed Nov 04, 2009 8:00 am    Post subject: Reply with quote
haha I have 2 8600 GT on Sli so they are pretty much useless now unless I get a motherboard that wont be usable in the future. haha
thanks for the other idea on the Hard drive, I'll look into both and compare them.
Back to top
ttotsbarc
PostPosted: Wed Nov 04, 2009 8:02 am    Post subject: Reply with quote
I'll probably go with the XFX4890 because I think it'll last longer and have better performance for the long run.
thanks though for the other suggestions on the video cards.
Back to top
ttotsbarc
PostPosted: Mon Nov 23, 2009 1:31 pm    Post subject: Reply with quote
So IM BUYING MY COMPUTER THIS FRIDAY (BLACK FRIDAY)!
I'm way stoked.
I have one more question...
I was planning on getting the XFX 4890:
but I notices the HIS 4890 that was reccomended to someone else:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161299&cm_re=4890-_-14-161-299-_-Product
I was thinking about getting the XFX because it seems to have a KILLER warranty but I noticed that the HIS is $20 cheaper (plus mail in rebate of $20 )
Which one would you all reccomend? Which one would last me the longest?
thanks for your inout and THANKS EVERYONE THAT HAS HELPED ME OUT ON THIS FORUM, YOU ALL ARE GREAT!
Back to top
Wingzero_x
PostPosted: Mon Nov 23, 2009 2:33 pm    Post subject: Reply with quote
Actually Black Monday is where you usually get the better deals at on-line stores.
And remember you're building your system, so you know what's in it, and you know where it's strengths and weaknesses lay, and can make the upgrades where necessary. And soon your friends, and family will be asking you to build them systems. Do two things, make sure you get paid, and don't tell them how easy it is!
Well good luck
Back to top
ttotsbarc
PostPosted: Mon Nov 23, 2009 2:48 pm    Post subject: Reply with quote
Well good luck
ya, I'm buying my parts online, at newegg and maybe tigerdirect. I'm hoping the parts that I get have deals on them this Friday, but if i don't see any deals i'll wait till Monday
thank
Back to top
Display posts from previous:
Post new topic   Reply to topic     Forum Index -> Help Me Buy/Help Me Build All times are GMT - 8 Hours
Page 1 of 1
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
Future © 2008 Future US, Inc. All Rights Reserved.
