It is currently Sat Jan 31, 2015 2:25 am
 Post subject: own mATX case
PostPosted: Sat Oct 31, 2009 1:28 pm
hello guys
first of all I'm sorry for my english..
..because I can't find case which meets my requirements, I decided to design my own case
Here is what I got so far
original size
http://i35.tinypic.com/2dhyxkk.png
top 120mm fan, back 3x80mm, W270xD270xH240mm
5.25" position is for Kaze Master
http://www.scythe-usa.com/product/acc/028/km01_detail.html
it's for a workstation, want it to be the smallest as possible but functional
CPU Intel i7, midrange VGA (waiting for new nvidia cards), MB msi X58M (chipset is about 65°C :cry: ), 2xHDD, no drives, no mess in cables
somewhere on the side of case will be USB ports, (maybe) handle on the top, feets on the bottom, noise reduction foam inside, considering to do the fan holes circular and remove the fans from the frame, but don't know if it increase noise (especialy two 80mm fans next to each other), what do you think?
next thing, do you think the top fan would be needed? I gave it here to do some flow around the chipset, but don't know if back fans are enough
appreciate any help or suggestions (for example better cards mounting :) )
PostPosted: Sat Oct 31, 2009 2:19 pm
Whoa!
Thats beautiful!
PostPosted: Sat Oct 31, 2009 2:36 pm
Looks nice. I think you'll run into some flexing and buzzing. Have another look at the top front and rear of the lower assembly to secure or strengthen the edges. In what program is that rendered?
PostPosted: Sat Oct 31, 2009 2:45 pm
Million Club [PC]
Million Club [PC]
why not put a 230mm fan in the top? Considering there isn't much in the form of intake on it... otherwise looks quite good. Only issue I see is that your expansion cards might not fit into that design- I'd say just leave the part of the back of the case that's directly over them empty, and then put it on the other part that slides onto it- that way you can slide your expansion cards in, and then putting the the top of the case back on secures them. So cut off the part I boxed in red:
and then put a flap on the other part of the case that covers that.
PostPosted: Sat Oct 31, 2009 2:54 pm
Edward6287: thanks, but I'm not sure if I understand what you mean by this :cry:
"Have another look at the top front and rear of the lower assembly to secure or strengthen the edges"
I want to stick that silicon seal (with groove) on the top part so it will hold case together (a little), you think that screws are not enough or metal sheet is thin?
btw. want let laser cut it out:) model is in Cinema4D, rendered by Fryrender
Spartacus: I guess intake with 120mm fan is enough, dont want it perforated too much because of dust and noise
standard expansion cards may fit, or I dont understand again :?:
dont want to give there bigger fan because of height of case and components under it
PostPosted: Sat Oct 31, 2009 2:58 pm
Million Club [PC]
Million Club [PC]
I edited my last post with a better idea. Expansion cards would fit, but I'm not sure how you would actually get them in there with that design is what I was saying. also, 230mm fans are actually quieter then 120mm fans, and you can just use a swiffer dry sheet for a filter. Did it with my case, works great.
PostPosted: Sat Oct 31, 2009 3:11 pm
thanks now I get it, thought I will put card in the MB and then slide it in:)
or just bend back to put card into a slot:)
I will consider to do a box of it and put bigger fan on the top:)
do you suggest intake or out take?
PostPosted: Sat Oct 31, 2009 3:18 pm
I'm looking at the bottom half of the case Up near the opening in front and the fans in back. I think you may get flexing since there is nothing holding the top edges together. With all the fans turned on, you might get vibration and buzzing along those edges.
At first, I thought that the silicon edging was just the edges of the metal. That might be enough to prevent buzzing.
PostPosted: Sun Nov 01, 2009 9:03 am
so guys, what do you think about the fans without frames?
tried to find something like 200mm fan, but here (czech republic) isn't much to choose from :cry: , more it's all for out take :?
do you know any good shop sending to another countries? maybe someone from Germany?
edit: do you know where could I find fan hole dimensions for these bigger fans? (at least screw holes pitch)
PostPosted: Sun Nov 01, 2009 9:55 am
See if this link helps: http://www.misco.de/
I do not know anything about the store. It is owned by the same corporation that owns TigerDirect and CompUSA. I found the link from a different discussion on the forum.
Please go back and resize your picture in the first post. It's too large to fit correctly into the forum format.
PostPosted: Sun Nov 01, 2009 10:28 am
thanks for the link, suppose I will make it cube and give 2x120mm intake fan to front top part
any ideas about fans without frames, anyone? 8)
anyway, thanks for all replies, I will post progress as soon as possible
PostPosted: Sun Nov 01, 2009 11:31 am
Million Club [PC]
Million Club [PC]
the fans without the frames should work fine. Just use a fan grill with them. In my experience, though, sometimes the vibration of the fan causes the grill to buzz- if that happens, what you want to do is take the parts of the fan grills that the screw goes through, and bend them down a bit so that the only part of the grill touching the case is the part that's screwed down. There are also silicon fan vibration dampeners that you can use in addition to that strategy- they're quite effective in my experience.
PostPosted: Mon Nov 02, 2009 3:33 pm
ok. just a minor update
usb holes added and top fan hole removed, now kaze wont be necessary, so I will remove 5.25" position as well
first thought was to do clean design case without much preforace and when I was doin that two top holes for fans I realized that this is not what I want to do (and it was ugly too :) ), I think that 27 cm is not so much for 80mm fan to take air from so maybe add one or two perforace lines to front part on sides?
it will probably need some test to do..
PostPosted: Fri Nov 06, 2009 3:48 pm
original size:
http://i36.tinypic.com/15n93d2.png
now I like it, but I don't know if the cooling is good enough..
PostPosted: Fri Nov 06, 2009 5:46 pm
rebit03 wrote:
original size:
Just cut 2 big holes in the front and put 2 fans there.
PostPosted: Sat Nov 07, 2009 2:33 am
Danthrax66: That's exactly what I don't want to do. Because then I can stay with the desing I posted here at first.
Anyway I am kinda busy so I think I can give it some time..
Thank you for comments.
PostPosted: Sat Nov 07, 2009 7:53 am
It is always better to have more intake than exhaust.
PostPosted: Sat Nov 07, 2009 8:05 am
ok, thank you
have to give it some time, maybe any idea will come along:)
or maybe I end up with what I post at first time..
PostPosted: Fri Nov 13, 2009 6:16 am
Um 2 quick questions.
First off, I dont see anyway for you to get Power Cables up to the motherboard tray from where the PSU is sitting. At least from the way your reneder looks, the motherboard tray completely covers the PSU and HDDs.
My last question is more of a concern. I know you are looking at a Midrange card, but remember cards are getting bigger, You might run into clearence issues with the length of the card.
To be on the safe side, I would add about an inch or so of extra space on the front side of the motherboard.
PostPosted: Fri Nov 13, 2009 8:41 am
Million Club [PC]
Million Club [PC]
not necessarily.
If the case has no passive holes or vents, then it doesn't much matter, there is almost no affect on case temps. But for ATX cases, if they have passive vents in front, its designed for negative pressure- you want negative case pressure so that cool air will be sucked in through those vents. But if the case has vents on the back or vented expansion slots, then you want positive pressure so that warm air is pushed out of those vents. Since he's designing his own case, he can choose whichever path he wants to take there. You can google "negative vs. positive case pressure" and probably find plenty of stuff that lays out all the pros and cons of the two methods.
