It is currently Tue Jan 27, 2015 3:01 pm
 Post subject: Web Development
PostPosted: Tue Oct 27, 2009 11:54 am
I'm interested in going to school for web development. Until I get get enrolled, are there any books you guys can recommend me reading to get my foot in the door (like what subjects should I check out)? I'm wanting to create different sites for businesses and maybe a design template site.
PostPosted: Tue Oct 27, 2009 1:55 pm
That really depends on how much you already know, gamergirl.
How much experience do you have?
PostPosted: Wed Oct 28, 2009 8:44 am
I'm a total novice.
PostPosted: Wed Oct 28, 2009 12:22 pm
GamerGirlsLoveMax wrote:
I'm a total novice.
Alrighty .. that makes it easy, actually. ;)
I recommend the '... for Dummies' line. Despite the insulting title, they are quite well written and very informative. Since you're a complete novice, I think you'll find that these will be a good starting point.
Honestly, the market is pretty saturated with people who just do design work. If you want to make decent money, you want to be a web developer, not a web designer. The difference is in the code .. a designer makes things pretty, while a developer makes sites that WORK. DB backends, store fronts, payment integration, custom scripting .. this is where people make money.
Hope that helps! I notice you asked a similar question a couple of years ago ... so I hope you get it moving this time .. inertia is the enemy!
PostPosted: Wed Oct 28, 2009 2:07 pm
Therefore momentum is your friend?
PostPosted: Wed Oct 28, 2009 3:43 pm
Umm .. no, but I misspoke.
Inertia is your enemy when you've no forward movement ... this is what I meant.
Remember that inertia is the conservation of momentum. Since she hasn't started, inertia keeps her still. Once she got the ball rolling, so to speak, inertia is the principle that keeps it moving (rather, that maintains her momentum).
</physics lecture>
Hepe we aren't geeking out too much in your thread, GG.
