It is currently Wed Mar 04, 2015 6:57 pm
 Post subject: ideas for adding a fan
PostPosted: Sun Oct 18, 2009 8:32 pm
I got a xigmatek 120mm hdt and was wondering if there is an easy or right way to attach a second fan. Also since I have a new hs my side fan doesn't fit so should I get new acrylic and replace the panel or maybe try to relocate the fan? My case is the antec 900.
PostPosted: Mon Oct 19, 2009 3:32 am
Post up some pictures of what you are thinking about doing and what your case looks like now.
PostPosted: Mon Oct 19, 2009 4:25 pm
TravBv2.0
TravBv2.0
I doubt you'll see a worth-while improvement on getting a second fan for your HDT-S1280 (that is what you're talking about, right?). Push-pull configs are only worth doing when you have a heatsink with lots of thick fins (Like Thermalright's IFX-14, or the good 'ol TRUE). Most heatsinks use relatively thin fins.
If you want my advice, the 900 is already overkill on airflow. I'd get a new plexiglass panel to replace the side-fanned one (just to fill up the whole) and call it a day. This really depends on your goals and the rest of your setup though.
PostPosted: Mon Oct 19, 2009 8:40 pm
i'm all about overkill haha but yeah you hit the nail on the head thanks.
PostPosted: Sun Oct 25, 2009 7:30 am
If you really wanted the extra airflow you could mount the fan on the outside of the case and use a fan grill.
