It is currently Sun May 03, 2015 7:03 pm
 Post subject: Recover Files from old Ubuntu
PostPosted: Sat Oct 17, 2009 6:09 pm
Okay so here's the situation: I have recently installed Win XP 64 bit and was going to have a triple-boot system going up.
The problem is that Windows XP 64 bit overwrote my GRUB install. Due to my past experiences trying to get a new GRUB, I have decided the whole thing is not worth the effort unless someone teaches me how to fix this up step by step.
Now, there's the new problem. I have files on my old Linux build that's gathering dust in my hard-drive. I can't delete it because I need those files. I still know my old password and user-name for it but the Ubuntu Live CD + permissions gayness i used to use won't let me get those files.
I'm sure someone here has done this before, so... anyone?
(I am planning to reinstall Ubuntu and wipe it on the new release)
PostPosted: Sat Oct 17, 2009 7:02 pm
This is probably your easiest solution...
http://www.fs-driver.org/faq.html
You could also reload grub via the livecd plenty of articles on how to do that via a google search.
PostPosted: Sun Oct 18, 2009 10:18 am
I believe Linux Mint live-cd's will allow you to access files on hard disk partitions. I may be wrong about this so correct me if I am wrong.
PostPosted: Sun Oct 18, 2009 1:10 pm
Actually any livecd will allow you to do that.
PostPosted: Sun Oct 18, 2009 1:23 pm
That's amazing!!!! +rep!
You saved me a bunch with that!
