ok so right now im at work, ill post some pictures of what i have and have done so far when i get home.
so i will try to explain what i am doing and what i will need in order to complete this.
ok so while i was looking around in the PX at all the crap i wish i could afford, i walked down an isle with a bunch of shelves and plastic storage drawer things.
i immediatly thought about computers for some reason. and how i can use one of those three drawer plastic things to put my 3 computers into to help save space in my barracks room.
it is very similar to this.
http://www.amazon.com/dp/B000KW00YO/ref ... B000KW00YO
i also got a much smaller desktop single drawer sollution that will hold my water cooling system for my main gaming/folding rig. it will be secured on top with velcro so i can remove it when i need to move the whole unit. i also have quck releases on the tubing so i can completely separate them.
what i need is:
2: motherboard trays that i can mount two of my mobo's on, i allready have one from an apeva case that i have.
25: 180mm fans. need to have decent airflow. but can be quiet aswell. if anybody has alot of them for cheap that would be great.
some way to securly mount the psu's to the plastic. if need be i will tear them down and drill holes in the metal casing and use zip ties to secure them.
i will also need alot of fan grills. nothing fancy. i wouldnt use them if i didnt have a problem with getting my fingers all cut up in the bastard fans.
oh and if anybody has a triple fan radiator for a water cooling system that they are willing to let go for a decent price. i will take it..
so yah i have bassically given up on the L4D project for the time being untill i get back to the states.
any other ideas for this project will be more than welcome. thanks for looking.
