It is currently Mon Apr 27, 2015 8:53 am
 Post subject: laptop HDs: 5400 RPM vs. 7200 RPM
PostPosted: Fri Jan 30, 2009 6:40 pm
I'm just curious: Is there a big difference (performance-wise) between a 5400 RPM drive and 7200 RPM drive?
(I know there will be some because faster is usually better, but am curious if it is worth the extra money to buy a 7200 RPM drive versus 5400 RPM drive.)
Also, is there any problem using a laptop (2.5") SATA drive in a desktop computer (I have a 2.5-to-3.5 adaptor and a spare drive). My reasoning is that I have a spare 2.5 laptop SATA drive and my main desktop drive died the other day, so I was thinking of using the laptop drive in the desktop for the time being (to save money).
The laptop drive has an 8MB cache, which is what my other system drive had. Except for my desktop drive was a 7200 RPM and the laptop drive is only a 5400 RPM.
PostPosted: Fri Jan 30, 2009 7:56 pm
Team Creamsicles
Team Creamsicles
There's a good amount of difference between the 7200RPM and 5400RPM drives. Windows will feel much snappier and programs will load faster.
The laptop drive will work in the desktop, but make sure you have a way of SECURING it. Zip ties could work if thought out.
 Post subject: Re: laptop HDs: 5400 RPM vs. 7200 RPM
PostPosted: Fri Jan 30, 2009 10:23 pm
If all else being equal (cache size, number of platters, etc.) then yes, there is a noticeable difference that can be perceived without the use of benchmarking utilities.
Only you can answer that as it comes down to two choices: would you rather have longer notebook battery life, or would you rather see more system performance? Personally, for notebook use, I prefer 5,400RPM hard drives mainly due to the fact that they consume less power. 7,200RPM hard drives perform better but they consume much more power than their 5,400RPM counterparts. It's whatever you feel is more important for your laptop needs.
Nope, there is no problem using laptop hard drives in a desktop solution. However, you need to understand that laptop HDD capacities cap out at 500GB, so you aren't going to see the insane capacities that Seagate and Western Digital have acheived in 3.5" hard drives in 2.5" HDD formfactor.
PostPosted: Sat Jan 31, 2009 6:30 am
TravBv2.0
TravBv2.0
Nope. If you happen to try an IDE 2.5" drive in a desktop, you'll need an adapter. They're not expensive though. For SATA, it'll work just like a desktop.
As far as securing the drive. most have found that elastic string makes for much better securing than zipties or rubber bands. Also setting it on a small piece of foam is good too.
PostPosted: Sat Jan 31, 2009 8:47 am
King of All Voodoo2 Cards
Further Reading on same topic over here:
http://www.maximumpc.com/forums/viewtop ... torder=asc
PostPosted: Sun Feb 01, 2009 8:29 pm
Million Club [PC]*
Million Club [PC]*
Um, people?
From my read on the OP, there's not a question of mounting the drive - he has a drivebay adapter for the notebook drive (I think. @ cbassett: that's a drivebay adapter that you have, yes? Not an IDE adapter?)
And, since it's SATA, the electrical connections are the same.
The only question is "will there be a performance hit?"
Answer: yes. Slower spindle speeds = slower read/write speeds. Simple as that.
But, you will be up & running. FWIW, though, hard drives are way cheap these days - you can get a 500GB desktop drive for less than $100.
PostPosted: Sun Feb 01, 2009 9:01 pm
cup wrote:
The only question is "will there be a performance hit?" Answer: yes. Slower spindle speeds = slower read/write speeds.
This was already established previously in the thread.
PostPosted: Mon Feb 02, 2009 4:52 am
Million Club [PC]*
Million Club [PC]*
Aware of that. However, of the four people that resonded:
- one only hit on mounting, and did not address the real question;
- one did address (a little) performance, and beat on mounting;
- one leaned his answer towards laptopland
- one linked to a thread that had already answered the question.
And, the OP had stated that he had the adapter needed.
PostPosted: Mon Feb 02, 2009 9:14 am
GIMME YO EXTRA CREDIT, BIZNATCHSKI!
PostPosted: Mon Feb 02, 2009 12:02 pm
Million Club [PC]*
Million Club [PC]*
Extra credit given, as well as a big box of cookies.
Preferred variety? I'm an Oreo man myself... 8)
PostPosted: Tue Feb 03, 2009 12:15 pm
PostPosted: Sun Jul 12, 2009 4:53 pm
Soon after buying my Lenovo S10, I upgraded to a 500GB Seagate 7200 rpm HD. I also upgraded to 2GB of memory.
http://www.seagate.com/www/en-us/produc ... us_7200.4/
I didn't do any benchmarking, but just from casual observation, I really can't see much improvement in speed or performance. In fact, when doing things like viewing photos & videos, or launching software, I don't think I can tell any difference at all. Perhaps it's due to the netbook's slow processor. Things might be different with a notebook (not netbook).
PostPosted: Wed Sep 23, 2009 1:47 pm
My guess is that the Netbook is the bottleneck.
and in the future, don't dredge old threads.
