It is currently Wed Jan 28, 2015 4:24 pm
 Post subject: Project: Ice Cream Headache
PostPosted: Thu Sep 17, 2009 9:49 pm
Remember back in day when I did a CraftStick Airplane PC? Well, even though a lot of people hated that project and wished I never did it. I still thought it was fun and wanted to revisit the idea. This time, however, I will make a case of craftsticks!
1st side is done
I don't want the case to be any wider than a CD/DVD drive
So I started by adding the lip on which the drive rests on
Like so....
Then I created the top and bottom of the case just wide enough
Second side is done
I use extra drives to stand it up
Then I make the lip wider
And stand both sides up
Then carefully add the top
Next comes the bottom. Adding the PSU helps press down the sticks for the glue to dry
The bowing sides will go away when the rest of the supports are added
Time to build the supports. This will cover the area below the DVD drive
Then the lip to the sides where the front will rest
Once it's added, I rest drives on top to even out the glue
After just four hours, I'm nearly done
PostPosted: Fri Sep 18, 2009 1:34 am
Team Member Top 250
Team Member Top 250
Wow, very nice case. Get bored? lol. I like the idea, but definitely don't have the patience for all that. Bravo for the pictures!
PostPosted: Fri Sep 18, 2009 5:02 am
Great work! I doubt at this point it needs to be said, but take your time. Don't want a heap of PC parts and Popsicle sticks. :wink:
PostPosted: Sat Sep 19, 2009 5:00 pm
So I measured out the back IO ports and PSU
And started on it
I then cut out some sticks for the front bottom to even it out
Here's just a shot of what the inside looks like
Next I framed out the CD drive. In this case beige really is the perfect color
Look at the front closely and you'll see the "V" pattern I glued on to break up the normal look of the craft sticks
I'm still working on the back though
PostPosted: Sun Sep 20, 2009 8:51 am
I created a small bridge over the PSU to anchor the rest of the back to
Then added some sticks to hold the PSU in place
And I am done! Enjoy the rest.
Thanks for Watching
PostPosted: Mon Sep 21, 2009 12:40 pm
Monkey Federation (Top 10)*
lolz! You crack me up.
PostPosted: Tue Sep 22, 2009 6:58 am
Team Member Top 250
Team Member Top 250
Interesting case. Seems you have quite a bit of time on your hands. Good job, but not exactly anything that I'm expecting to throw on top of my desk. Cool tho, thanks for the pictures! Keep the cool mods coming! :D
PostPosted: Fri Dec 11, 2009 3:28 pm
Team Member Top 250
Team Member Top 250
so how sturdy is it?
PostPosted: Fri Dec 11, 2009 7:56 pm
No power button?
