It is currently Sun Jan 25, 2015 9:29 am
 Post subject: batch file? end process tree
PostPosted: Sun Sep 13, 2009 5:19 am
i tap on picture to play video. media player loads but somtimes video won't play. i close media player tap on a differt picture . some times media player won't even pop up. so i have to do this; task manager is already on desktop. process tab . right click on wmpnscfg.exe. tap on end process. tap next box to end process. when i tap back on picture media player loads and plays video. is ther abatch file tha can do this. and could it be assinged to the desktop? :roll:
PostPosted: Sun Sep 13, 2009 6:52 am
taskkill /IM wmpnscfg.exe /F
put that in kill WMP.bat and enjoy.
 Post subject: batch file end process tree
PostPosted: Mon Sep 14, 2009 12:51 pm
thank's for reply . i have no idea where to type this or put it?
PostPosted: Mon Sep 14, 2009 3:12 pm
Open notepad.
Copy in the stuff in the "code" tag.
Save it as "KillWMP.bat" (you'll need to change the file type to All files *.* or it may add the .txt extention).
Save and run when you need to kill WMP.
PostPosted: Tue Sep 15, 2009 12:45 pm
thanks again i followed directions and it' s in my doc folder and my desktop. i' ll leave one more post next time i have to end media player should be tommorow to let you know. thanks again.
PostPosted: Thu Sep 17, 2009 12:53 pm
back again. i put this code on desktop. taped on picture ' the mediaplayer loaded but video didn't play. i closed mediaplayer. taped on another picture. media player loaded but video didn't play. this is where i use task manager to get video to play. as described before. i taped on the desktop flie you wrote at this time . what happened is the command promt window flashed then disappeared. to get the video to play i used the task manager .
 Post subject: Re: batch file end process tree
PostPosted: Thu Sep 17, 2009 3:02 pm
Yes, that is how batch files work. If you just double click them the window comes up and goes away when the command is done.
You may be killing the wrong process with the command.
PostPosted: Fri Sep 18, 2009 1:29 pm
thanks forall your help i'll be closing this post now
