It is currently Fri Mar 27, 2015 1:08 pm
 Post subject: Vista/Firefox Help
PostPosted: Tue Aug 25, 2009 7:29 pm
I'm on a two week old Toshiba, from best buy, but as ove very late, the only internet I could run is IE 64-bit. This is a problem, as I run and am accustomed to Firefox. Any help? I've already scanned with Super spyware. Got rid of all Mal-Ware.
PostPosted: Wed Aug 26, 2009 12:35 am
I think you're going to have to explain a little bit more of what your problem is. You can't just "Firefox doesn't work" and expect a legit suggestion on how to fix it.
Describe your issue in detail so the guys here have something to work with.
PostPosted: Wed Aug 26, 2009 4:29 am
Fair enough. Firefox will not load any pages. It shows the same screen as it would if you were not connected to the internet and tried to load something. It recommends that I should check my computers network connections and see if firefox is permitted to access the internet.
PostPosted: Wed Aug 26, 2009 4:54 am
team psycho or sumthin
Just to get it out of the way...
In FF, Tools>options, select Advanced, on the Network tab, hit the Settings button. Select No Proxy or Auto Detect Proxy.
PostPosted: Wed Aug 26, 2009 8:11 am
Tried that. Didn't work. I tried to import the setting from my 64-bit IE (which still works) when I re-installed Firefox. Didn't work.
PostPosted: Wed Aug 26, 2009 8:13 am
Monkey Fed [PC]
Monkey Fed [PC]
So, according to your first post, you had a heavily infected machine? With lots of malware and other nasty's? Is there any way you can post a HiJackThis! log for us so we can be sure it's all gone? I think you may still be infected.
PostPosted: Wed Aug 26, 2009 2:15 pm
Here is log-
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 4:14:32 PM, on 8/26/2009
Platform: Windows Vista SP1 (WinNT 6.00.1905)
MSIE: Internet Explorer v7.00 (7.00.6001.18294)
Boot mode: Normal
Running processes:
C:\Program Files (x86)\Dropbox\Dropbox.exe
C:\Users\Owner\MagicFormation.exe
C:\Program Files (x86)\TOSHIBA\TOSHIBA USB Sleep and Charge Utility\TUSBSleepChargeSrv.exe
C:\Program Files (x86)\CyberLink\PowerCinema for TOSHIBA\PCMAgent.exe
C:\Program Files (x86)\Java\jre6\bin\jusched.exe
C:\Program Files (x86)\TOSHIBA\ConfigFree\NDSTray.exe
C:\Program Files (x86)\CyberLink\PowerCinema for TOSHIBA\Kernel\CLML\CLMLSvc.exe
C:\Program Files (x86)\TOSHIBA\ConfigFree\CFSwMgr.exe
C:\Program Files (x86)\Trend Micro\HijackThis\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = www.google.com
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
F2 - REG:system.ini: UserInit=userinit.exe
O1 - Hosts: ::1 localhost
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files (x86)\Java\jre6\bin\ssv.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre6\bin\jp2ssv.dll
O4 - HKLM\..\Run: [TUSBSleepChargeSrv] %ProgramFiles(x86)%\TOSHIBA\TOSHIBA USB Sleep and Charge Utility\TUSBSleepChargeSrv.exe
O4 - HKLM\..\Run: [TWebCamera] "%ProgramFiles(x86)%\TOSHIBA\TOSHIBA Web Camera Application\TWebCamera.exe" autorun
O4 - HKLM\..\Run: [StartupDelayer] "C:\Program Files (x86)\r2 Studios\Startup Delayer\Startup Launcher.exe"
O4 - HKLM\..\Run: [ToshibaServiceStation] "C:\Program Files" (x86)\TOSHIBA\TOSHIBA Service Station\ToshibaServiceStation.exe /hide:60
O4 - HKLM\..\Run: [PCMAgent] "C:\Program Files (x86)\CyberLink\PowerCinema for TOSHIBA\PCMAgent.exe"
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files (x86)\Java\jre6\bin\jusched.exe"
O4 - HKLM\..\Run: [cfFncEnabler.exe] "C:\Program Files (x86)\TOSHIBA\ConfigFree\cfFncEnabler.exe"
O4 - HKLM\..\Run: [StartCCC] "C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe" MSRun
O4 - HKLM\..\Run: [NDSTray.exe] "C:\Program Files (x86)\TOSHIBA\ConfigFree\NDSTray.exe"
O4 - HKLM\..\Run: [CLMLServer] "C:\Program Files (x86)\CyberLink\PowerCinema for TOSHIBA\Kernel\CLML\CLMLSvc.exe"
O4 - HKCU\..\Run: [ehTray.exe] C:\Windows\ehome\ehTray.exe
O4 - HKCU\..\Run: [CollaborationHost] C:\Windows\system32\p2phost.exe -s
O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\Run: [WindowsWelcomeCenter] rundll32.exe oobefldr.dll,ShowWelcomeCenter (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /detectMem (User 'NETWORK SERVICE')
O4 - Startup: Dropbox.lnk = C:\Program Files (x86)\Dropbox\Dropbox.exe
O4 - Startup: MagicFormation.lnk = C:\Users\Owner\MagicFormation.exe
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~2\MICROS~2\Office12\EXCEL.EXE/3000
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~2\MICROS~2\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~2\MICROS~2\Office12\ONBttnIE.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~2\MICROS~2\Office12\REFIEBAR.DLL
O10 - Unknown file in Winsock LSP: c:\windows\system32\wpclsp.dll
O10 - Unknown file in Winsock LSP: xfire_lsp_9028.dll
O13 - Gopher Prefix:
O16 - DPF: {FFB3A759-98B1-446F-BDA9-909C6EB18CC7} (PCPitstop Exam) - http://utilities.pcpitstop.com/Optimize3/pcpitstop2.dll
O20 - Winlogon Notify: !SASWinLogon - C:\Program Files (x86)\SUPERAntiSpyware\SASWINLO.dll
O23 - Service: Agere Modem Call Progress Audio (AgereModemAudio) - Unknown owner - C:\Windows\system32\agr64svc.exe (file missing)
O23 - Service: @%SystemRoot%\system32\Alg.exe,-112 (ALG) - Unknown owner - C:\Windows\System32\alg.exe (file missing)
O23 - Service: AMD External Events Utility - Unknown owner - C:\Windows\system32\atiesrxx.exe (file missing)
O23 - Service: TOSHIBA Web Camera Service (camsvc) - TOSHIBA - C:\Program Files (x86)\TOSHIBA\TOSHIBA Web Camera Application\TWebCameraSrv.exe
O23 - Service: ConfigFree Gadget Service - TOSHIBA CORPORATION - C:\Program Files (x86)\TOSHIBA\ConfigFree\CFProcSRVC.exe
O23 - Service: ConfigFree Service - TOSHIBA CORPORATION - C:\Program Files (x86)\TOSHIBA\ConfigFree\CFSvcs.exe
O23 - Service: @dfsrres.dll,-101 (DFSR) - Unknown owner - C:\Windows\system32\DFSR.exe (file missing)
O23 - Service: Intel(R) PROSet/Wireless Event Log (EvtEng) - Intel(R) Corporation - C:\Program Files\Intel\WiFi\bin\EvtEng.exe
O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files (x86)\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files (x86)\Common Files\InstallShield\Driver\1150\Intel 32\IDriverT.exe
O23 - Service: @%windir%\system32\inetsrv\iisres.dll,-30007 (IISADMIN) - Unknown owner - C:\Windows\system32\inetsrv\inetinfo.exe (file missing)
O23 - Service: @keyiso.dll,-100 (KeyIso) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Program Files (x86)\Common Files\LightScribe\LSSrvc.exe
O23 - Service: @comres.dll,-2797 (MSDTC) - Unknown owner - C:\Windows\System32\msdtc.exe (file missing)
O23 - Service: @%SystemRoot%\System32\netlogon.dll,-102 (Netlogon) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\psbase.dll,-300 (ProtectedStorage) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: Intel(R) PROSet/Wireless Registry Service (RegSrvc) - Intel(R) Corporation - C:\Program Files\Common Files\Intel\WirelessCommon\RegSrvc.exe
O23 - Service: @%systemroot%\system32\Locator.exe,-2 (RpcLocator) - Unknown owner - C:\Windows\system32\locator.exe (file missing)
O23 - Service: TOSHIBA Modem region select service (RSELSVC) - TOSHIBA Corporation - C:\Program Files\TOSHIBA\rselect\RSelSvc.exe
O23 - Service: @%SystemRoot%\system32\samsrv.dll,-1 (SamSs) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\SLsvc.exe,-101 (slsvc) - Unknown owner - C:\Windows\system32\SLsvc.exe (file missing)
O23 - Service: @%SystemRoot%\system32\snmptrap.exe,-3 (SNMPTRAP) - Unknown owner - C:\Windows\System32\snmptrap.exe (file missing)
O23 - Service: @%systemroot%\system32\spoolsv.exe,-1 (Spooler) - Unknown owner - C:\Windows\System32\spoolsv.exe (file missing)
O23 - Service: Steam Client Service - Valve Corporation - C:\Program Files (x86)\Common Files\Steam\SteamService.exe
O23 - Service: TOSHIBA HDD Protection (Thpsrv) - Unknown owner - C:\Windows\system32\ThpSrv.exe (file missing)
O23 - Service: TMachInfo - TOSHIBA Corporation - C:\Program Files (x86)\TOSHIBA\TOSHIBA Service Station\TMachInfo.exe
O23 - Service: TOSHIBA Navi Support Service (TNaviSrv) - TOSHIBA Corporation - C:\Program Files (x86)\TOSHIBA\TOSHIBA DVD PLAYER\TNaviSrv.exe
O23 - Service: TOSHIBA Optical Disc Drive Service (TODDSrv) - Unknown owner - C:\Windows\system32\TODDSrv.exe (file missing)
O23 - Service: TOSHIBA Power Saver (TosCoSrv) - TOSHIBA Corporation - C:\Program Files\TOSHIBA\Power Saver\TosCoSrv.exe
O23 - Service: TOSHIBA HDD SSD Alert Service - TOSHIBA Corporation - C:\Program Files\TOSHIBA\TOSHIBA HDD SSD Alert\TosSmartSrv.exe
O23 - Service: TPCH Service (TPCHSrv) - TOSHIBA Corporation - C:\Program Files\TOSHIBA\TPHM\TPCHSrv.exe
O23 - Service: @%SystemRoot%\system32\ui0detect.exe,-101 (UI0Detect) - Unknown owner - C:\Windows\system32\UI0Detect.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vds.exe,-100 (vds) - Unknown owner - C:\Windows\System32\vds.exe (file missing)
O23 - Service: @%systemroot%\system32\vssvc.exe,-102 (VSS) - Unknown owner - C:\Windows\system32\vssvc.exe (file missing)
O23 - Service: @%Systemroot%\system32\wbem\wmiapsrv.exe,-110 (wmiApSrv) - Unknown owner - C:\Windows\system32\wbem\WmiApSrv.exe (file missing)
O23 - Service: @%ProgramFiles%\Windows Media Player\wmpnetwk.exe,-101 (WMPNetworkSvc) - Unknown owner - C:\Program Files (x86)\Windows Media Player\wmpnetwk.exe (file missing)
O23 - Service: @%windir%\system32\inetsrv\iisres.dll,-20001 (WMSvc) - Unknown owner - C:\Windows\system32\inetsrv\wmsvc.exe (file missing)
End of file - 10105 bytes
Don't know what it means, but I'm just saying that all Mal-Ware was removed that was found by Super. I'm no expert, and in research, I found that Norton causes this problem, but I got rid of all norton, and all malware I can find. I may still have some bugs.
PostPosted: Wed Aug 26, 2009 5:06 pm
NEW INFO! New HJT.
Scan saved at 7:05:50 PM, on 8/26/2009
Boot mode: Normal
Running processes:
C:\Program Files (x86)\SUPERAntiSpyware\SUPERAntiSpyware.exe
End of file - 10049 bytes
