It is currently Mon Mar 30, 2015 9:13 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
 Post subject: Why is the server so slow tonight?
PostPosted: Fri Apr 17, 2009 7:31 pm
Monkey Fed [PC]
Monkey Fed [PC]
Every where but here is really fast tonight. I've been all over the internet so I know it's not my ISP or something....anyone know what's up?
PostPosted: Fri Apr 17, 2009 8:21 pm
I'm experiencing the same thing, so no your not going crazy. :D
PostPosted: Fri Apr 17, 2009 9:17 pm
Monkey Fed [PC]
Monkey Fed [PC]
Thank goodness!! I was beginning to think Qwest was having issues again.
PostPosted: Wed Aug 26, 2009 5:50 am
Hi
You have a problem of slow server this problem might occur if there is a problem with your service provider. If you have a broadband connection then try to check your routers and modem status. I hope this suggestion helps you.
PostPosted: Wed Aug 26, 2009 7:23 am
Super Mario Banhammer
shawnwilliams wrote:
Hi
Wow who let the M$ Tech guy in the room?
PostPosted: Wed Aug 26, 2009 7:25 am
Monkey Fed [PC]
Monkey Fed [PC]
Considering I'm the OP, and the problem was waaaayyyy back in April, and ONLY affected the MPC website, it wasn't an ISP problem, lol.
