It is currently Tue Mar 03, 2015 11:02 pm
 Post subject: Python question
PostPosted: Sat Aug 22, 2009 2:01 pm
Hey guys, I'm having a problem with a very simple database test. I need to be able to find the key to a specific value, and check to see if a value exists. This is what I have (I've bolded the parts that I need help on, and put in fake methods that hopefully explain what I need to do with it.:
-edit- Could I just search for the value in a list of the values and then get the key from that? I know I can use this for finding if the value exists, but I'm pressed for time and need to go do something, so I'll edit it when I can. -/edit-
-edit2- O.O The post took all of my formatting! :( -/edit2-
Thanks in advance!
import pdb
class Basic_Files
   #instantiate main variables
   phonebook = {}
   option = 3
   choice = 1
   new_name = ""
   new_number = ""
   look_up_name = ""
   loop_up_num = ""
   y/n = ""
   loop = 1
   while loop == 1:
      print "Welcome to a basic phone book."
      print "Please choose a number:"
      print "[1] Add a new name"
      print "[2] Find a number"
      print "[3] Close the phonebook"
                pdb.set_trace()
      try:
         option = input(">> ")
      except KeyboardInterrupt, err:
         print "Keyboard input interrupted, Closing,"
         loop = 0
      else:
         if option == 1:
            print "Please enter the new name."
            new_name = input(">> ")
            if phonebook.has_key(new_name):
               print "That entry already exists!"
            else:
               print "Please enter the new number."
               new_number = input(">> ")
               if phonebook.[b]has_value(new_number)[/b]:
                  print "This number already exists!"
               else:
                  phonebook [new_name] = new_number
                  print "Entry complete. Would you like to view it now?"
                  y/n = input("[y/n] >> ")
                  if y/n == "y":
                     print phonebook[new_name]
                  else:
         elif option == 2:
            print "Please choose:"
            print "[1] Find a name"
            try:
               choice = input(">> ")
               print "Keyboard input interrupted, closing."
               loop = 0
            else:
               if choice == 1:
                  print "Please insert the number:"
                  try:
                     look_up_num = input(">> ")
                     loop = 0
                  else:
                     if phonebook.[b]has_value(look_up_num):[/b]
                        print phonebook.[b]key_of(look_up_num)[/b]
         elif option == 3:
            loop = 0
         else:
            loop = 1
Edit by smartcat99s: added code tags
PostPosted: Sat Aug 22, 2009 9:58 pm
Million Club - 5 Plus*
Try getting a list of items by using dictionary.values() and then working from there.
