It is currently Sun Feb 01, 2015 2:13 am
 Post subject: Doctype messes up background
PostPosted: Sat Aug 22, 2009 1:34 am
Centered, the website has a picture on the top, two colums in the middle, then a footer on the bottom. When I don't have a doctype, it works, but when I put a strict doctype the background around the mid section disappears.
If I remove the floats, the background appears correctly, but the two columns in the middle are stacked on top of each other.
The code does validate according to http://validator.w3.org/.
Here's a simplified version of the page:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<title>Title</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
</head>
<body style="background-color: blue;">
<div style="width: 1024px; height: 100%; margin: 0px auto; background-color: white; display: block;">
   <img style="width: 1024px; height: 200px;" src="pic.jpg" alt="pic">
   <div style="width: 150px; float: left; display: block;">
      <p>dfjk;lasdk</p>
   </div>
   <div style="width:850; float: left; display: block;">
      <p>adlsfjlk</p>
   </div>
   <div style="width:1024; float: left; display: block;">
      <p>adlsfjlk45365tregwerg4</p>
   </div>
</div>
</body>
</html>
PostPosted: Sun Aug 23, 2009 9:59 pm
I found the solution. It was as simple as putting <br style="clear: both"> at the end before the last </div>. I found the answer from http://www.glish.com/css/3.asp.
Here is the final code:
<html>
<head>
</head>
      <p>dfjk;lasdk</p>
   </div>
      <p>adlsfjlk</p>
   </div>
   <div style="width:1024; float: left; clear: both; display: block;">
   </div>
</div>
</body>
</html>
PostPosted: Mon Aug 24, 2009 8:47 am
Apparently I spoke too soon. It now works properly in IE, FF, but doesn't work properly in chrome.
PostPosted: Wed Aug 26, 2009 8:23 pm
Hopefully Ithis will be the last time I post here. I found the solution (hopefully). I just had to add overflow: hidden; to the first div. When I did that, the <br> tag at the end was no longer necessary.
