It is currently Mon Jan 26, 2015 2:25 am
 Post subject: need some help here
PostPosted: Sun Nov 14, 2004 11:04 am
here is my problem my computer shut down every time i want to play a game. I can play it for about 10 mintues then it shut down. It don't matter what game it is. any idea would be helpful
Thanks
Matt :(
PostPosted: Sun Nov 14, 2004 11:29 am
sounds like it's overheating...do you have a thermal monitoring program installed?
PostPosted: Sun Nov 14, 2004 5:05 pm
Yep, sounds like an overheating problem.
Check to make sure all your fans are operational. CPU, video card, power supply.
If your CPU in particular is overheating, your BIOS may have a safety feature that's automatically shutting down the PC when it reaches a certain temp...or it's just putzing out because it's starting to melt :shock:
