It is currently Thu Jan 29, 2015 2:22 am
 Post subject: How do you turn off the FPS counter in D3?
PostPosted: Mon Nov 08, 2004 4:32 am
I know how to turn it on, but how the hell do I turn it off. I found a nice console command list on google, but it does'nt say how to turn it off. Thanks for any help. -Mac
PostPosted: Mon Nov 08, 2004 5:55 am
use the same command that you used to turn it on but instead of the "1" at the end put a zero "0".
Use com_showFPS 1 to turn it on.
Use com_showFPS 0 to turn it off.
On a related note... The 1 stands for "true" or "on" while the 0 stands for "false" or "off". Any other commands that have a 1 or 0 at the end uses this convention.
PostPosted: Mon Nov 08, 2004 6:01 am
Thanks for the tip! -Mac
